I just installed Egroupware but the FileManager doesn’t work.
I have the error message : Base directory does not exist, Ask adminstrator to check the global configuration.
I saw in the forums that I have to create directories out of the docroot directory and to put all acces.
So, I think I did it :
-For the path users and groups I made the directory : F:\xampplite\Egroupware_Files
-I put all privileges for the user apache that I created.
-I put this path F:\xampplite\Egroupware_Files in the configuration setup for users and groups.
My configuration is, Xampplite and apache is running as a service.
My OS is Windows Xp Pro.
Can you Help me please?
Thanks,
Bests regards.
