Ralf,all,
This is probably a pear/upstream issue, but I wanted to make you aware of it
as well. During install of egw 1.8.005 svn on new server, I encountered a
problem installing pear/MDB2_Driver_sqlite. pear install refused to install the
sqlite extension complaining that it required PHP extension “sqlite”. I have the
PHP-sqlite package installed:
[06:48 phoinix:/srv/http/htdocs] # pmq | grep sqlite
php-sqlite 5.5.6-1
sqlite 3.8.1-2
sqlite-doc 3.8.1-2
sqlite-tcl 3.8.1-2
and both extension=pdo_sqlite.so, and extension=sqlite3.so enabled in php.ini.
Despite having php-sqlite installed and the extensions enabled in php.ini, pear
refused to install pear/MDB2_Driver_sqlite with the following error:
[06:51 phoinix:/srv/http/htdocs] # pear install pear/MDB2_Driver_sqlite
pear/MDB2_Driver_sqlite requires PHP extension "sqlite"
No valid packages found
install failed
pear refused to install the driver requiring a --force to install it:
[06:53 phoinix:/srv/http/htdocs] # pear install -f MDB2_Driver_sqlite
warning: pear/MDB2_Driver_sqlite requires PHP extension "sqlite"
downloading MDB2_Driver_sqlite-1.4.1.tgz …
Starting to download MDB2_Driver_sqlite-1.4.1.tgz (30,921 bytes)
…done: 30,921 bytes
install ok: channel://pear.php.net/MDB2_Driver_sqlite-1.4.1
I don’t understand why pear is not seeing the php-sqlite extension. My only
guess is that since the extension in php.ini is “sqlite3.so” pear doesn’t find
it. I also don’t know why it doesn’t see the pdo_sqlite.so extension.
Does anybody have any additional insight into this problem? I’ll look for a
place to report it at pear.php.net. If anyone has a link handy, I would
appreciate that as well.
Just for information, my full pear install ended up as:
[06:53 phoinix:/srv/http/htdocs] # pear list
Installed packages, channel pear.php.net:
Package Version State
Archive_Tar 1.3.11 stable
Auth_SASL 1.0.6 stable
Console_Getopt 1.3.1 stable
DB 1.7.14 stable
Log 1.12.7 stable
MDB2 2.4.1 stable
MDB2_Driver_mysql 1.4.1 stable
MDB2_Driver_sqlite 1.4.1 stable
PEAR 1.9.4 stable
Structures_Graph 1.0.4 stable
XML_Feed_Parser 1.0.5 stable
XML_Util 1.2.1 stable
The only other issues on pear install was that pear suggested the beta
versions of Auth_SASL2 and Console_GetoptPlus. However, when attempting install,
you receive failures due to the “beta” status of the packages:
Failed to download pear/Auth_SASL2 within preferred state “stable”, latest
release is version 0.1.0, stability “beta”, use
"channel://pear.php.net/Auth_SASL2-0.1.0" to install
Failed to download pear/Console_GetoptPlus within preferred state “stable”,
latest release is version 1.0.0RC1, stability “beta”, use
"channel://pear.php.net/Console_GetoptPlus-1.0.0RC1" to install
Does egw make use of any of the features in the beta packages?
David C. Rankin, J.D.,P.E.
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
