Files are in a sub-directory, but URL is a subdomain. We are using
ISPConfig as control panel, could that be a problem too?
Yeah, that is the problem.
Subdomain does not matter, currently EGroupware can NOT be installed
directly in the document root aka the url /.
2015-09-30 1:54 GMT-03:00 Ralf Becker Stylite AG [via EGroupware]
<[hidden email] </user/SendEmail.jtp?type=node&node=4009244&i=0>>:
Could it be you installed direct into the document root, that's
currently not supported.
Just use a sub-directory eg. /egroupware as our packages do.
> I've made a fresh install of EGroupware 14.3.005 but after login
I see just
> these
<http://egroupware.219119.n3.nabble.com/file/n4009167/Main-Screen.jpg>
> Found trailing slash on eGroupWare's URL, but after fixed that
the problem
> persists.
> Any clue?
