That’s not enough I guess. You have to import the untrusted certificate into your certificate store.
i have the same problem.
i have a other message in sync.txt
00:08:20:165 [DEBUG] - Connecting to office.xxx.com:443
00:08:20:165 [DEBUG] - Requesting resource /rpc.php
00:08:20:255 [DEBUG] - Message sent
00:08:20:255 [DEBUG] - Reading response...
00:08:20:255 [DEBUG] - Content-length: 709
00:08:20:255 [DEBUG] - Response read
00:08:20:265 [ERROR] - Server Failure: server returned error code -1
00:08:20:265 [ERROR] - Error in syncing: Server Failure: server returned error code -1
00:08:20:265 [INFO] - Tasks sync completed with errors
00:08:20:265 [DEBUG] - Enter restoreSlowSyncBackup method
00:08:20:275 [DEBUG] - Exit restoreSlowSyncBackup method
00:08:20:305 [INFO] - Logged off from Outlook
the message is the same if i change the user password - so i think it doesn’t work to the correct login and it will be blocked before.
i have also insert the adress to the trused sites in IE - but doesn’t help
IE = version 7.
maybe there is a problem ?!?
cu camel
Hi uplide
in the browser I see "You should access this URL only with a SyncML enabled device"
but the certificate is a self signed one.
Thanks again. Miche
[/quote]
[/quote]
