Hi urodelo,
thanks for the tip. The application is available in the Market and I will do some testing.
Using Gmail as carrier for my egw contacts is really no problem, but for me this is a one-way sync… Contacts changed / added on my phone should be synced back into egw, without addidtional handling / routines.
It all worked in egw 1.6.002 (signing in, syncing) then came 1.6.003 which broke signing in (but was able to sync when intermediate signing in was done against 1.6.002), now version 1.8.003 breaks both signing in and syncing…
Looking at the speed Android is gaining momentum in the ‘pda’ market in my opinion this should be fixed / looked at… but then again: I’m biased because I just want it to work
Thanks again for thinking along!
regards,
Ruud.
