hi,
i want to reply some users in window group … doesn’t know but i have no rights to do that.
however - maybe tis helps some other guys …
SYNCML + EGW
(my tests)
can also said: that it works now good with syncml (funambol 6.0.5 + outlook 2003 + EGW 1.3.19 trunk always up2date)
SYNCML: whats does not working or is not supported or where are some problems ?
.) sync with “one-way-Sync from outlook to server” -> i’m working on it to fix/implement this (hope done next days)
.) recover sync with “one-way-Sync from outlook to server” -> i’m working on it to fix/implement this (hope done next days)
.) encyrption is not supported or doesn’t work for me. -> (not real encrypt - only xored) no idea why - i hope to check this next days and to do areport to devels
.) calendar items - recurring events with exceptions -> open issue, don’t know if somebody can fix this or have the time to do
.) distribution list - not supported by EGW and funambol -> hope to get it supported by the next month
.) HEX-0A string in values of contact-items after syncing on some systems -> solution is in sight (hope next days it is fixed)
.) on infolog, it doesn’t use all items - only the new one which are in future
.) on calendar items. also not all items are taken if a full sync is requested
so maybe you have tried to sync with the one-way sync method ?, because then the “error of content length 0” is normal.
otherwise try the version funambol 6.0.5, because there are a lot of parts inside, which fixed a lot of “content lenght errors”.
Almost you get an error message in your php.log file.
So please see, if there are errors on your php.logs.
cu camel
