hi,
seit wir die neue version von egw (1.4.002) aufgespielt haben funktioniert bei uns das syncen mit funambol nicht mehr. Funambol sagt…
aber ich hab die daten mehrmals neu eingegeben und mehrmals kontrolliert, die sind auf jedenfall richtig.
Hier das logfile von funambol:
08:01:26 GMT +1:00 [DEBUG] - Reading configuration settings from the management tree
08:01:27 GMT +1:00 [DEBUG] - [UI] StartSync begin
08:01:27 GMT +1:00 [DEBUG] - [UI] Hide menu
08:01:27 GMT +1:00 [DEBUG] - [UI] Starting the syncThread…
08:01:27 GMT +1:00 [DEBUG] - Starting the Sync process…
08:01:27 GMT +1:00 [DEBUG] - Set a lower priority to the process
08:01:27 GMT +1:00 [DEBUG] - Set listeners
08:01:27 GMT +1:00 [DEBUG] - Creating SyncSources…
08:01:27 GMT +1:00 [DEBUG] - Creating the sync-mutex (“fol-SyncInProgress-1194591687”)
08:01:27 GMT +1:00 [DEBUG] - Start SyncClient::Sync() with 2 sources
08:01:27 GMT +1:00 [INFO] -
************************** BEGIN of Synchronization session **************************
08:01:27 GMT +1:00 [INFO] - Synchronization URL: http://Unser Server/egroupware/rpc.php
08:01:27 GMT +1:00 [INFO] - Preparing synchronization of contact…
08:01:27 GMT +1:00 [INFO] - Preparing synchronization of appointment…
08:01:27 GMT +1:00 [DEBUG] - devinfo: 1.1
Funambol
Funambol Outlook Plug-in
6.0.14
fol-VkVSTEVJSE5JWDpmdW5hbWJvbA==
workstation
contact
text/x-s4j-sifc
text/x-s4j-sifc
text/x-vcard
2.1
text/x-s4j-sifc
text/x-s4j-sifc
text/x-vcard
2.1
2
1
5
3
6
4
appointment
text/x-s4j-sife
text/x-s4j-sife
text/x-vcalendar
1.0
text/x-s4j-sife
text/x-s4j-sife
text/x-vcalendar
1.0
2
1
5
3
6
4
08:01:27 GMT +1:00 [DEBUG] - devinfo hash: hNppQA/cPzdvLmqU4jlDkA==
08:01:27 GMT +1:00 [DEBUG] - devinfo changed, retransmit
08:01:27 GMT +1:00 [DEBUG] - Initialization message:
08:01:27 GMT +1:00 [DEBUG] - <?xml version="1.0" encoding="UTF-8"?>
1.1
SyncML/1.1
1194591687
1
b64
syncml:auth-basic
c3ZlbjpteVQzdmkwbg==
250000
1
200
sifcontacts
contact
0
1194591687
2
200
sifcalendar
appointment
0
1194591687
3
application/vnd.syncml-devinf+xml
./devinf11
1.1
Funambol
6.0.14
workstation
contact
text/x-s4j-sifc
text/x-s4j-sifc
text/x-vcard
2.1
text/x-s4j-sifc
text/x-s4j-sifc
text/x-vcard
2.1
2
1
5
3
6
4
appointment
text/x-s4j-sife
text/x-s4j-sife
text/x-vcalendar
1.0
text/x-s4j-sife
text/x-s4j-sife
text/x-vcalendar
1.0
2
1
5
3
6
4
08:01:27 GMT +1:00 [DEBUG] - User Agent = Funambol Outlook Plug-in v. 6.0.14
08:01:27 GMT +1:00 [DEBUG] - Initialization sent.
08:01:27 GMT +1:00 [DEBUG] - Connecting to **Unser Server**:80
08:01:27 GMT +1:00 [DEBUG] - Requesting resource /egroupware/rpc.php
08:01:27 GMT +1:00 [DEBUG] - Sending data of size 2719...
08:01:27 GMT +1:00 [DEBUG] - Message sent
08:01:27 GMT +1:00 [DEBUG] - Finished sending data of size 2719.
08:01:27 GMT +1:00 [DEBUG] - Header:
08:01:27 GMT +1:00 [DEBUG] - Reading response...
08:01:27 GMT +1:00 [DEBUG] - Content-length: 0
08:01:27 GMT +1:00 [DEBUG] - Undefined content-length = 0. Using the maxMsgSize = 512000.
08:01:27 GMT +1:00 [DEBUG] - Receiving data of size 512000...
08:01:27 GMT +1:00 [DEBUG] - Finished receiving data of size 187.
08:01:27 GMT +1:00 [DEBUG] - Response read:
Fatal error: Call to a member function getSync() on a non-object in
/usr/share/egroupware/phpgwapi/inc/horde/Horde/SyncML/Command/Alert.php on line
328
08:01:27 GMT +1:00 [ERROR] - Error processing SyncHdr Status
08:01:27 GMT +1:00 [DEBUG] - Checking for forced slow-sync…
08:01:27 GMT +1:00 [DEBUG] - ---------------------- contact BEGIN (mode “two-way”) ----------------------
08:01:27 GMT +1:00 [DEBUG] - beginSync of contact source: opening Outlook session…
08:01:27 GMT +1:00 [DEBUG] - Initialize COM library
08:01:27 GMT +1:00 [DEBUG] - Create Outlook.Application instance…
08:01:28 GMT +1:00 [DEBUG] - Logon to Outlook MAPI: default profile, show-dialog = true, new-session = false
08:01:28 GMT +1:00 [INFO] - Outlook session opened successfully! Using: Outlook 2003.
08:01:28 GMT +1:00 [DEBUG] - Reading ALL contacts from folder ‘\Persönliche Ordner\Kontakte’ (0 found)…
08:01:28 GMT +1:00 [INFO] - Cannot find list of items from previous sync. All items will be sent as modified.
08:01:28 GMT +1:00 [INFO] - Total contact items to send: 0
08:01:28 GMT +1:00 [DEBUG] - Modification message: estimated size 0, allowed size 250000, real size 709 / estimated size 0 = 100%
08:01:28 GMT +1:00 [DEBUG] - <?xml version="1.0" encoding="UTF-8"?>
1.1
SyncML/1.1
1194591687
2
1
1
0
SyncHdr
http://**Unser Server**/egroupware/rpc.php
200
2
sifcontacts
contact
08:01:28 GMT +1:00 [DEBUG] - Modifications sent.
08:01:28 GMT +1:00 [DEBUG] - Connecting to **Unser Server**:80
08:01:28 GMT +1:00 [DEBUG] - Requesting resource /egroupware/rpc.php
08:01:28 GMT +1:00 [DEBUG] - Sending data of size 709...
08:01:28 GMT +1:00 [DEBUG] - Message sent
08:01:28 GMT +1:00 [DEBUG] - Finished sending data of size 709.
08:01:28 GMT +1:00 [DEBUG] - Header:
08:01:28 GMT +1:00 [DEBUG] - Reading response...
08:01:28 GMT +1:00 [DEBUG] - Content-length: 942
08:01:28 GMT +1:00 [DEBUG] - Receiving data of size 942...
08:01:28 GMT +1:00 [DEBUG] - Finished receiving data of size 942.
08:01:28 GMT +1:00 [DEBUG] - Response read:
1.1SyncML/1.111945916872fol-VkVSTEVJSE5JWDpmdW5hbWJvbA==http://**Unser Server**/egroupware/rpc.phphttp://**Unser Server**/egroupware/rpc.php?syncml_sessionid=syncml-f33433bd30011142510c44ae92da6a42120SyncHdrhttp://**Unser Server**/egroupware/rpc.phpfol-VkVSTEVJSE5JWDpmdW5hbWJvbA==b64syncml:auth-basic407222Syncsifcontactscontact200
08:01:28 GMT +1:00 [ERROR] - Server Failure: server returned error code 407
08:01:28 GMT +1:00 [DEBUG] - ---------------------- END (mode "none") ----------------------
08:01:28 GMT +1:00 [DEBUG] - Server requested syncmode "none" for .
08:01:28 GMT +1:00 [DEBUG] - Error occurred in sync: code 3 = Server Failure: server returned error code 407
08:01:28 GMT +1:00 [ERROR] - Error in syncing: Server Failure: server returned error code 407
================ SYNCHRONIZATION REPORT ================
SYNCHRONIZATION COMPLETED WITH ERRORS
Last error message = "Server Failure: server returned error code 407"
Last error code = 407
Contacts:
Sync completed successfully!
Sync type: two-way
| on Client | on Server
New | 0/ 0 | 0/ 0
Updated | 0/ 0 | 0/ 0
Deleted | 0/ 0 | 0/ 0
Calendar:
Not synced.
08:01:28 GMT +1:00 [DEBUG] - Saving configuration to winRegistry
08:01:28 GMT +1:00 [DEBUG] - Writing configuration settings to the management tree
08:01:28 GMT +1:00 [DEBUG] - Closing Outlook…
08:01:28 GMT +1:00 [DEBUG] - Deleting ClientApplication instance
08:01:28 GMT +1:00 [INFO] - Outlook session closed successfully.
08:01:28 GMT +1:00 [DEBUG] - Closing COM library…
08:01:28 GMT +1:00 [DEBUG] - Releasing sync-mutex…
08:01:28 GMT +1:00 [DEBUG] - Sync-mutex released - closing handle.
08:01:28 GMT +1:00 [DEBUG] - Delete SyncSources…
08:01:28 GMT +1:00 [INFO] - Syncronization process completed with errors (code = 407).
08:01:29 GMT +1:00 [DEBUG] - Reading configuration settings from the management tree
08:01:30 GMT +1:00 [DEBUG] - Reading configuration settings from the management tree
