HI Fabien,
did you checked the “remote settings” under “syncronisation settings”.
I am working fine with the following settings.
Please look in the PDF. (I hope the upload worked)
funambol.pdf (15.7 KB)
Greetings Marc
Hello the community,
I finally managed to find time to migrate from eGW 1.0 to 1.2 (new
installation on a new machine).
Everything is working fine, so I try the synchronisation.
Client : Outlook 2002 with Funambol 3.0.15
Server : eGW 1.2.105 (ready from Mandriva 2007)
Connecting on http://monserveur/egroupware/rpc.php : all is fine.
(except the ‘normal’ warning about using a SyncML client and not my
browser).
In /tmp/egroupware_syncml.log no errors.
In /tmp/sync/ many XML files with no strange error messages.
On the client side, logs say that all has worked fine.
The only problem, is that even if all logs files are clean, no data are
updated/created/deleted.
I’ve tried for calendar, contacts and tasks from Outlook to eGW and from
eGW to Outlook.
What did I miss ?
Thks a lot for any help.
BRgds,
Fabien
[/quote]
