I have searched this error here but I found no solution, so here we are!
I’m trying to configure Outlook sync, I have domain “default” and “abcxyz.com” with LDAP auth, I’ve tried with Egosync but it doesn’t seems to work (maybe for the same reason Funambol won’t work too).
I’ve set mbstring overload to 0 , Funambol seems to login but it gets :
12:06:03 GMT +1:00 [DEBUG] - Reading response…
12:06:03 GMT +1:00 [DEBUG] - Content-length: 250
12:06:03 GMT +1:00 [DEBUG] - Receiving data of size 250…
12:06:03 GMT +1:00 [DEBUG] - Finished receiving data of size 250.
12:06:03 GMT +1:00 [DEBUG] - Response read:
An error happend
An error happend
Wrong domain! 'abcxyz.com' != 'default'
Click here to resume your eGroupWare Session.
12:06:03 GMT +1:00 [ERROR] - Error processing SyncHdr Status
12:06:03 GMT +1:00 [DEBUG] - Error occurred in sync: code 3 = Error reading status code of command 'SyncHdr’
12:06:03 GMT +1:00 [ERROR] - Error in preparing sync: Error reading status code of command 'SyncHdr’
12:06:03 GMT +1:00 [INFO] -
My authentication is correct, my login is "user@abcxyz.com" , if I cut “abcxyz.com” funambol returns me login error, so it’s not an auth problem.
It seems , like I see in some other messages here, that rpc.php has some problems with different domains? Is it possible or I miss something in the configuration?
regards
Simon
