I installed the latest stable release of egroupware (1.0.0x) to a Redhat
server.
This webhosting company made virtual servers, normally working, no problem.
When I setup the absolute path (/home/httpd/vhosts/domain.hu/tmp) for
configuring the document root, the filemanager told me the Base directory not
exist.
We checked the path, I gave read/write permissions to world, but it
never can use this directory.
If I wrote the /tmp, which is out of my virtual environment, it can use
that directory as base directory and the app working well.
The guy checked the permissions and said, the apache is able to
read/write that directory (/home/httpd/vhosts/domain.hu/tmp), but the
application said:“Base directory does not exist, Ask adminstrator to
check the global configuration”.
So, how can I check, what the hack happened?
I don’t like to use the database to store files.
Maybe I have to setup something in php.ini too?
Any help/tipps are really welcome
Regards,
István
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
