ich habe den gleichen Fehler erhalten und bin zu blöd, den Fehler zu finden, kann mir jemand helfen?
Ajax Anfrage fehlgeschlagen: OK (200)
URL: http:egw.emmbit.de/json.php?menuaction=mail.jdots_framework.ajax_exec.template
PHP:
PHP Version 5.5.9-1ubuntu4.5
System Linux websrv04 3.13.0-45-generic #74-Ubuntu SMP Tue Jan 13 19:36:28 UTC 2015 x86_64
Build Date Oct 29 2014 11:58:05
Server API FPM/FastCGI
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php5/fpm
Loaded Configuration File /etc/php5/fpm/php.ini
Scan this dir for additional .ini files /etc/php5/fpm/conf.d
Additional .ini files parsed /etc/php5/fpm/conf.d/05-opcache.ini, /etc/php5/fpm/conf.d/10-mysqlnd.ini, /etc/php5/fpm/conf.d/10-pdo.ini, /etc/php5/fpm/conf.d/20-gd.ini, /etc/php5/fpm/conf.d/20-imap.ini, /etc/php5/fpm/conf.d/20-intl.ini, /etc/php5/fpm/conf.d/20-json.ini, /etc/php5/fpm/conf.d/20-mcrypt.ini, /etc/php5/fpm/conf.d/20-mysql.ini, /etc/php5/fpm/conf.d/20-mysqli.ini, /etc/php5/fpm/conf.d/20-pdo_mysql.ini, /etc/php5/fpm/conf.d/20-readline.ini
Directive
Local Value
Master Value
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
disable_classes no value no value
disable_functions show_source,system,shell_exec,passthru,exec,shell,symlink,proc_open,popen show_source,system,shell_exec,passthru,exec,shell,symlink,proc_open,popen
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
enable_post_data_reading On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 32759 32759
exit_on_timeout Off Off
expose_php Off Off
extension_dir /usr/lib/php5/20121212 /usr/lib/php5/20121212
file_uploads On On
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors Off Off
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/share/php:/usr/share/pear .:/usr/share/php:/usr/share/pear
log_errors Off Off
log_errors_max_len 1024 1024
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 90 90
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 180 180
max_input_vars 1000 1000
memory_limit 1024M 1024M
open_basedir /var/www/virtual/emmbit.de/:/usr/share/php:/usr/share/pear/ /var/www/virtual/emmbit.de/:/usr/share/php:/usr/share/pear/
output_buffering 4096 4096
output_handler no value no value
post_max_size 1024M 1024M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
report_memleaks On On
report_zend_debug On On
request_order GP GP
Einzig wird in den Logs folgendes ausgegeben:
===================== schnipp =====================================================
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /projectmanager/templates/pixelegg/images/navbar.png HTTP/1.1” 200 1700 "http://egw.emmbit.de/index.php?cd=yes$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /resources/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2788 “http://egw.emmbit.de/index.php?cd=yes” "Mo$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /timesheet/templates/pixelegg/images/navbar.png HTTP/1.1” 200 3129 “http://egw.emmbit.de/index.php?cd=yes” "Mo$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /tracker/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2733 “http://egw.emmbit.de/index.php?cd=yes” "Mozi$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /filemanager/templates/pixelegg/images/navbar.png HTTP/1.1” 200 3139 “http://egw.emmbit.de/index.php?cd=yes” "$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /wiki/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2574 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /bookmarks/templates/pixelegg/images/navbar.png HTTP/1.1” 200 1583 “http://egw.emmbit.de/index.php?cd=yes” "Mo$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /sitemgr/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2322 “http://egw.emmbit.de/index.php?cd=yes” "Mozi$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /news_admin/templates/pixelegg/images/navbar.png HTTP/1.1” 200 1838 “http://egw.emmbit.de/index.php?cd=yes” "M$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /phpbrain/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2850 “http://egw.emmbit.de/index.php?cd=yes” "Moz$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /etemplate/templates/pixelegg/images/navbar.png HTTP/1.1” 200 2949 “http://egw.emmbit.de/index.php?cd=yes” "Mo$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /developer_tools/templates/default/images/navbar.png HTTP/1.1” 200 2252 "http://egw.emmbit.de/index.php?cd=yes$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /pixelegg/images/scroll.png HTTP/1.1” 200 846 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla/5.0 (Windows NT$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /pixelegg/images/ajax-loader.gif HTTP/1.1” 200 875 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla/5.0 (Windo$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /pixelegg/images/splitter_vert.png HTTP/1.1” 200 398 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla/5.0 (Win$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “GET /pixelegg/images/close_button.png HTTP/1.1” 200 252 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla/5.0 (Wind$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:04 +0100] “POST /json.php?menuaction=mail.jdots_framework.ajax_exec.template HTTP/1.1” 200 308 "http://egw.emmbit.de/index.ph$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:18:05 +0100] “GET /pixelegg/images/dialog_error.png HTTP/1.1” 200 594 “http://egw.emmbit.de/index.php?cd=yes” "Mozilla/5.0 (Wind$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:19:08 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:20:28 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:21:45 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:22:45 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:23:03 +0100] “POST /json.php?menuaction=notifications.notifications_ajax.get_notifications HTTP/1.1” 200 94 "http://egw.emmbit.d$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:23:46 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:24:47 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:25:48 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:26:49 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:27:49 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” "Microsoft-WebDAV-MiniRedir/6.3.9600"
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:28:04 +0100] “POST /json.php?menuaction=notifications.notifications_ajax.get_notifications HTTP/1.1” 200 94 "http://egw.emmbit.d$
xxx.xxx.xxx.xxx - - [12/Feb/2015:07:28:50 +0100] “PROPFIND /filemanager/webdav.php HTTP/1.1” 207 1126 “-” “Microsoft-WebDAV-MiniRedir/6.3.9600”
===================== schnapp =====================================================
Wie man sieht, der WebDAV Zugriff funktioniert.
Wollte Ralf jetzt nicht damit belasten, er hat sicherlich den Kopf voll mit der Bereitstellung von 14.2.
Grüße Detlev
