Hi All,
I have been struggling with this for a while. Kept getting a request for
a password, I would put it in then another request etc… Strange thing
is sometimes it would work and an event would be added, but then the
Tbird calendar would be set to read only! Set it back to read-write and
the calendar would go out of sync…
Anyway, I could not find a clear answer in any one place, but I put the
following together and it works smoothly!
I’m running EGW 14.2.005 on CentOS 6.7.
You must do all of this as “root”!
Go to /usr/share/egroupware and open up the file egroupware.htaccess for
editing, I used VIM. You should see a line “ReWriteEngine On” followed
by lines containing several ReWriteRule and ReWriteCond statements. At
the end of those start a new line and add the following line:
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
Save the file and exit. Copy the egroupware.htaccess file to .htaccess
in the same directory.
Go to the folder /etc/httpd/conf.d . Open the file egroupware.conf for
editing. Find the section that starts with <Directory
/usr/share/egroupware/>. In that section should be a line that reads
"AllowOverride None". Change that to read “AllowOverride FileInfo”. Save
the file and exit.
Restart the apache web server: service httpd restart.
You are done! I hope this is helpful to someone!
Thomas E. Plancon
CAD/IS Manager
B K A Architects, Inc.
142 Crescent Street
Brockton, MA 02302
tel: 508 . 583 . 5603 ext 313
fax: 508 . 584 . 2914
www.bkaarchitects.com http://www.bkaarchs.com/
