Hi all, I have a problem with guacamole, I installed guacamole with the command HTTP_HOST=mysite.net apt install egroupware-guacamole with no errors, but I can’t find it among the installed applications, I checked the container is up, I checked the entry in the opeid , and it is present, I checked in the setup panel and the application appears to be installed. How can I solve the problem?
Hi Giuseppe.
Please check the (your) run right for the application Guacamole. If you have no run rights, you even can not see Guacamole in admin/applications.
You are probably not using the Default (all-users) group, for which the installation automatically adds run rights.
Default
So you need to add run rights for Guacamole manually to the group(s) you use.
