Hi Dave,
you problem is EGroupware depending on php >= 5.2.1.
There are two solutions for CentOS:
a) use current PHP 5.3.10 from IUS Community repo:
http://iuscommunity.org/Docs/ClientUsageGuide
Basic installation is:
wget
http://dl.iuscommunity.org/pub/ius/stable/Redhat/5/x86_64/ius-release-1-2.ius.el5.noarch.rpm
wget
http://dl.iuscommunity.org/pub/ius/stable/Redhat/5/x86_64/epel-release-1-1.ius.el5.noarch.rpm
rpm -Uvh ius-release*.rpm epel-release*.rpm
yum install php53u-common php53-cli php53u-pear
b) use older php 5.3 from CentOS 5.7:
yum install php53-common php53-cli php-pear
I recommend a), as that’s what we use in our EGroupware hosting too.
After that you install EGroupware.
I’ve got a server running Centos 5.7 under xen virtualization. It
primarily hosts web sites, a few lists and some email. I’ve added the
following repo data:
[server_eGroupWare]
name=eGroupware (CentOS_5)
type=rpm-md
baseurl=http://download.opensuse.org/repositories/server:/eGroupWare/CentOS_5/
gpgcheck=1
gpgkey=http://download.opensuse.org/repositories/server:/eGroupWare/CentOS_5/repodata/repomd.xml.key
enabled=1
This is in a file, appropriately named, in /etc/yum.repos.d
Yum knows about it and finds the data and this is what happens when I
try to install eGW:
]# yum install eGroupware
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- base: mirror.its.sfu.ca
- extras: mirror.its.sfu.ca
- updates: mirror.its.sfu.ca
base | 1.1 kB 00:00
extras | 2.1 kB 00:00
server_eGroupWare | 1.3 kB 00:00
updates | 1.9 kB 00:00
Setting up Install Process
Resolving Dependencies
–> Running transaction check
—> Package eGroupware.noarch 0:1.8.002.20111111-2.1 set to be updated
–> Processing Dependency: eGroupware-egw-pear>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-tracker>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-projectmanager>=
1.8.002.20111111 for package: eGroupware
–> Processing Dependency: eGroupware-phpsysinfo>= 1.8.002.20111111
–> Processing Dependency: eGroupware-registration>= 1.8.002.20111111
–> Processing Dependency: eGroupware-polls>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-wiki>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-syncml>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-developer_tools>=
–> Processing Dependency: eGroupware-manual>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-core>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-emailadmin>= 1.8.002.20111111
–> Processing Dependency: eGroupware-filemanager>= 1.8.002.20111111
–> Processing Dependency: eGroupware-phpfreechat>= 1.8.002.20111111
–> Processing Dependency: eGroupware-news_admin>= 1.8.002.20111111
–> Processing Dependency: eGroupware-sambaadmin>= 1.8.002.20111111
–> Processing Dependency: eGroupware-infolog>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-bookmarks>= 1.8.002.20111111
–> Processing Dependency: eGroupware-phpbrain>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-felamimail>= 1.8.002.20111111
–> Processing Dependency: eGroupware-resources>= 1.8.002.20111111
–> Processing Dependency: eGroupware-importexport>= 1.8.002.20111111
–> Processing Dependency: eGroupware-timesheet>= 1.8.002.20111111
–> Processing Dependency: eGroupware-sitemgr>= 1.8.002.20111111 for
package: eGroupware
–> Processing Dependency: eGroupware-notifications>=
–> Processing Dependency: eGroupware-calendar>= 1.8.002.20111111 for
package: eGroupware
—> Package eGroupware-bookmarks.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-calendar.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-core.noarch 0:1.8.002.20111111-2.1 set to be updated
–> Processing Dependency: php>= 5.2.1 for package: eGroupware-core
–> Processing Dependency: php-mysql for package: eGroupware-core
–> Processing Dependency: php-pear for package: eGroupware-core
–> Processing Dependency: php-gd for package: eGroupware-core
–> Processing Dependency: php-mbstring for package: eGroupware-core
–> Processing Dependency: php-xml for package: eGroupware-core
–> Processing Dependency: php-mcrypt for package: eGroupware-core
—> Package eGroupware-developer_tools.noarch 0:1.8.002.20111111-2.1
set to be updated
—> Package eGroupware-egw-pear.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-emailadmin.noarch 0:1.8.002.20111111-2.1 set
to be updated
–> Processing Dependency: php-imap for package: eGroupware-emailadmin
—> Package eGroupware-felamimail.noarch 0:1.8.002.20111111-2.1 set
to be updated
–> Processing Dependency: tnef for package: eGroupware-felamimail
—> Package eGroupware-filemanager.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-importexport.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-infolog.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-manual.noarch 0:1.8.002.20111111-2.1 set to be updated
—> Package eGroupware-news_admin.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-notifications.noarch 0:1.8.002.20111111-2.1
set to be updated
—> Package eGroupware-phpbrain.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-phpfreechat.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-phpsysinfo.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-polls.noarch 0:1.8.002.20111111-2.1 set to be updated
—> Package eGroupware-projectmanager.noarch 0:1.8.002.20111111-2.1
set to be updated
–> Processing Dependency: jpgraph>= 1.13 for package:
—> Package eGroupware-registration.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-resources.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-sambaadmin.noarch 0:1.8.002.20111111-2.1 set
to be updated
—> Package eGroupware-sitemgr.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-syncml.noarch 0:1.8.002.20111111-2.1 set to be updated
—> Package eGroupware-timesheet.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-tracker.noarch 0:1.8.002.20111111-2.1 set to
be updated
—> Package eGroupware-wiki.noarch 0:1.8.002.20111111-2.1 set to be updated
—> Package jpgraph.noarch 0:3.0.7-2.1 set to be updated
–> Processing Dependency: php>= 5.1.2 for package: jpgraph
—> Package php-gd.x86_64 0:5.1.6-27.el5_7.5 set to be updated
–> Processing Dependency: php-common = 5.1.6-27.el5_7.5 for package: php-gd
—> Package php-imap.x86_64 0:5.1.6-27.el5_7.5 set to be updated
—> Package php-mbstring.x86_64 0:5.1.6-27.el5_7.5 set to be updated
—> Package php-mcrypt.x86_64 0:5.1.6-15.el5.centos.1 set to be updated
—> Package php-mysql.x86_64 0:5.1.6-27.el5_7.5 set to be updated
–> Processing Dependency: php-pdo for package: php-mysql
—> Package php-pear.noarch 1:1.4.9-6.el5 set to be updated
—> Package php-xml.x86_64 0:5.1.6-27.el5_7.5 set to be updated
—> Package tnef.x86_64 0:1.4.7-1.1 set to be updated
—> Package php.x86_64 0:5.1.6-27.el5_7.5 set to be updated
–> Processing Dependency: php-cli = 5.1.6-27.el5_7.5 for package: php
—> Package php-common.x86_64 0:5.1.6-27.el5_7.5 set to be updated
—> Package php-pdo.x86_64 0:5.1.6-27.el5_7.5 set to be updated
—> Package php-cli.x86_64 0:5.1.6-27.el5_7.5 set to be updated
–> Processing Conflict: php53-common conflicts php-common
–> Finished Dependency Resolution
eGroupware-core-1.8.002.20111111-2.1.noarch from server_eGroupWare has
depsolving problems
–> Missing Dependency: php>= 5.2.1 is needed by package
eGroupware-core-1.8.002.20111111-2.1.noarch (server_eGroupWare)
php53-common-5.3.3-1.el5_7.6.x86_64 from installed has depsolving problems
–> php53-common conflicts with php-common
Error: php53-common conflicts with php-common
Error: Missing Dependency: php>= 5.2.1 is needed by package
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
I’ve tried the suggested remedies with no luck. So any advice?
references to more reading?
--------- part 2 -----------
I have not used eGW before. I’d like the users of a specific site to
access it through a URL like site.tld/ecal for the CalAV function,
which is is all I plan to use. I don’t know how or how difficult to
set up this is. Advice here would be welcome, too.
Thanks very much,
Dave
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
