Webseite bringt: 502 Bad Gateway (nginx/1.22.0)
Logs sagen:
2022/09/30 11:11:13 [error] 23#23: *13 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "GET /egroupware/login.php HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:11:14 [error] 23#23: *13 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "GET /egroupware/login.php HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:11:15 [error] 23#23: *13 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "GET /egroupware/login.php HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:11:47 [error] 23#23: *14 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "REPORT /egroupware/groupdav.php/einedomain.com/calendar/ HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:11:48 [error] 23#23: *14 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "PROPFIND /egroupware/groupdav.php/einedomain.com/addressbook/ HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:12:10 [error] 23#23: *13 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "GET /egroupware/login.php?phpgw_forward=%252Findex.php HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:12:44 [error] 23#23: *15 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "REPORT /egroupware/groupdav.php/einedomain.com/calendar/ HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:12:59 [error] 23#23: *15 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "REPORT /egroupware/groupdav.php/einedomain.com/calendar/ HTTP/1.1", host: "ein.host.ihrerwahl"
2022/09/30 11:12:59 [error] 23#23: *15 egroupware could not be resolved (2: Server failure), client: 172.19.0.1, server: _, request: "PROPFIND /egroupware/groupdav.php/einedomain.com/addressbook/ HTTP/1.1", host: "ein.host.ihrerwahl"
Sehe ich das richtig, dass da ein Hostname “egroupware” via DNS aufgelöst werden will?
Containers sind up - aber müsste da nicht noch einer mehr sein?
[root@mail egroupware-docker]# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
35051dd0410a nginx:stable-alpine "/docker-entrypoint.…" 2 months ago Up 12 minutes 127.0.0.1:8080->80/tcp egroupware-nginx
d815b83ef031 quay.io/egroupware/collabora-key:stable "/start-collabora-on…" 3 months ago Up 21 minutes 127.0.0.1:9980->9980/tcp collabora-key
d881378a550d phpswoole/swoole:4.6-php7.4-alpine "docker-php-entrypoi…" 7 months ago Up 21 minutes egroupware-push
b3972385b4ea containrrr/watchtower:latest "/watchtower --sched…" 8 months ago Up 21 minutes 8080/tcp egroupware-watchtower
Das ganze läuft auf Rocky 8/CentOS/RHEL8
Folgende packages wurden aktualisiert
Package Arch Version Repository Size
Installing:
kernel x86_64 4.18.0-372.26.1.el8_6 baseos 8.1 M
kernel-core x86_64 4.18.0-372.26.1.el8_6 baseos 39 M
kernel-devel x86_64 4.18.0-372.26.1.el8_6 baseos 21 M
kernel-modules x86_64 4.18.0-372.26.1.el8_6 baseos 32 M
Upgrading:
bpftool x86_64 4.18.0-372.26.1.el8_6 baseos 8.8 M
ca-certificates noarch 2022.2.54-80.2.el8_6 baseos 919 k
chrony x86_64 4.1-1.el8.rocky.0.1 baseos 326 k
dnsmasq x86_64 2.79-21.el8_6.1 appstream 319 k
egroupware-docker noarch 21.1.20220916-1.1 server_eGroupWare 341 k
firefox x86_64 102.3.0-6.el8_6 appstream 108 M
gnome-settings-daemon x86_64 3.32.0-16.el8_6.1 appstream 1.0 M
gnupg2 x86_64 2.2.20-3.el8_6 baseos 2.4 M
gnupg2-smime x86_64 2.2.20-3.el8_6 baseos 282 k
initscripts x86_64 10.00.17-1.el8_6.2 baseos 339 k
iproute x86_64 5.15.0-4.el8_6.1 baseos 797 k
iproute-tc x86_64 5.15.0-4.el8_6.1 baseos 463 k
java-1.8.0-openjdk-headless x86_64 1:1.8.0.345.b01-1.el8_6 appstream 34 M
kernel-headers x86_64 4.18.0-372.26.1.el8_6 baseos 9.4 M
kernel-tools x86_64 4.18.0-372.26.1.el8_6 baseos 8.3 M
kernel-tools-libs x86_64 4.18.0-372.26.1.el8_6 baseos 8.1 M
libdnf x86_64 0.63.0-8.2.el8_6 baseos 705 k
libvirt-daemon x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 417 k
libvirt-daemon-config-network x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 66 k
libvirt-daemon-driver-interface x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 208 k
libvirt-daemon-driver-network x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 234 k
libvirt-daemon-driver-nodedev x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 218 k
libvirt-daemon-driver-nwfilter x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 233 k
libvirt-daemon-driver-qemu x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 921 k
libvirt-daemon-driver-secret x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 196 k
libvirt-daemon-driver-storage x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 64 k
libvirt-daemon-driver-storage-core x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 252 k
libvirt-daemon-driver-storage-disk x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 74 k
libvirt-daemon-driver-storage-gluster x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 76 k
libvirt-daemon-driver-storage-iscsi x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 72 k
libvirt-daemon-driver-storage-iscsi-direct x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 73 k
libvirt-daemon-driver-storage-logical x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 75 k
libvirt-daemon-driver-storage-mpath x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 69 k
libvirt-daemon-driver-storage-rbd x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 79 k
libvirt-daemon-driver-storage-scsi x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 71 k
libvirt-daemon-kvm x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 63 k
libvirt-libs x86_64 8.0.0-5.4.module+el8.6.0+1000+18e3b59f appstream 4.7 M
mariadb x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 6.0 M
mariadb-backup x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 6.1 M
mariadb-common x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 63 k
mariadb-errmsg x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 234 k
mariadb-gssapi-server x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 51 k
mariadb-server x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 16 M
mariadb-server-utils x86_64 3:10.3.35-1.module+el8.6.0+1005+cdf19c22 appstream 1.1 M
nspr x86_64 4.34.0-3.el8_6 appstream 142 k
nss x86_64 3.79.0-10.el8_6 appstream 746 k
nss-softokn x86_64 3.79.0-10.el8_6 appstream 1.2 M
nss-softokn-freebl x86_64 3.79.0-10.el8_6 appstream 397 k
nss-sysinit x86_64 3.79.0-10.el8_6 appstream 73 k
nss-tools x86_64 3.79.0-10.el8_6 appstream 581 k
nss-util x86_64 3.79.0-10.el8_6 appstream 137 k
pam x86_64 1.3.1-16.el8_6.1 baseos 739 k
perf x86_64 4.18.0-372.26.1.el8_6 baseos 10 M
platform-python x86_64 3.6.8-47.el8_6.rocky.0 baseos 86 k
python3-hawkey x86_64 0.63.0-8.2.el8_6 baseos 116 k
python3-libdnf x86_64 0.63.0-8.2.el8_6 baseos 777 k
python3-libs x86_64 3.6.8-47.el8_6.rocky.0 baseos 7.8 M
python3-libvirt x86_64 8.0.0-1.1.module+el8.6.0+1000+18e3b59f appstream 331 k
python3-perf x86_64 4.18.0-372.26.1.el8_6 baseos 8.2 M
qemu-guest-agent x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 343 k
qemu-img x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 2.2 M
qemu-kvm x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 167 k
qemu-kvm-block-curl x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 178 k
qemu-kvm-block-gluster x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 179 k
qemu-kvm-block-iscsi x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 185 k
qemu-kvm-block-rbd x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 180 k
qemu-kvm-block-ssh x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 180 k
qemu-kvm-common x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 1.1 M
qemu-kvm-core x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 3.4 M
qemu-kvm-docs x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 2.6 M
qemu-kvm-hw-usbredir x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 189 k
qemu-kvm-ui-opengl x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 181 k
qemu-kvm-ui-spice x86_64 15:6.2.0-11.module+el8.6.0+1000+18e3b59f.5 appstream 227 k
scap-security-guide noarch 0.1.63-1.el8_6.rocky.0.4 appstream 15 M
swtpm x86_64 0.7.0-3.20211109gitb79fd91.module+el8.6.0+1000+18e3b59f appstream 42 k
swtpm-libs x86_64 0.7.0-3.20211109gitb79fd91.module+el8.6.0+1000+18e3b59f appstream 48 k
swtpm-tools x86_64 0.7.0-3.20211109gitb79fd91.module+el8.6.0+1000+18e3b59f appstream 118 k
systemd x86_64 239-58.el8_6.7 baseos 3.6 M
systemd-container x86_64 239-58.el8_6.7 baseos 757 k
systemd-libs x86_64 239-58.el8_6.7 baseos 1.1 M
systemd-pam x86_64 239-58.el8_6.7 baseos 483 k
systemd-udev x86_64 239-58.el8_6.7 baseos 1.6 M
webkit2gtk3 x86_64 2.36.7-1.el8_6 appstream 19 M
webkit2gtk3-jsc x86_64 2.36.7-1.el8_6 appstream 6.8 M
Installing dependencies:
libatomic x86_64 8.5.0-10.1.el8_6 baseos 23 k
Removing:
kernel x86_64 4.18.0-372.9.1.el8 @baseos 0
kernel-core x86_64 4.18.0-372.9.1.el8 @baseos 69 M
kernel-devel x86_64 4.18.0-372.9.1.el8 @baseos 52 M
kernel-modules x86_64 4.18.0-372.9.1.el8 @baseos 23 M
Transaction Summary
Install 5 Packages
Upgrade 84 Packages
Remove 4 Packages
