Hi David,
CalDAV by default sync all events you participate or you’re invited.
Ralf, all,
With sync working for the iphone 4, what is the best way get shared events
to sync to each person’s device? For example, Ralf adds an event to the
calender and when david syncs his calender to his iphone, he will see the
event that Ralf added.
What I have done so far is to just grant access to calendars on a per user
basis and then to add a common group as the participant for the event in the
event entry ‘Participant’ tab.
I don’t know if both are necessary. I think I could probably get away with
using the common group as the participant, but I though I would check here to
see what the ‘proper’ way to do it was.
Is the rule that the “iphone gets all the events that the user is a
participant of”, or does it work some other way?
David C. Rankin, J.D.,P.E.
AppSumo Presents a FREE Video for the SourceForge Community by Eric
Ries, the creator of the Lean Startup Methodology on “Lean Startup
Secrets Revealed.” This video shows you how to validate your ideas,
optimize your ideas and identify your business strategy.
http://p.sf.net/sfu/appsumosfdev2dev
BlackBerry® DevCon Americas, Oct. 18-20, San Francisco, CA
The must-attend event for mobile developers. Connect with experts.
Get tools for creating Super Apps. See the latest technologies.
Sessions, hands-on labs, demos & much more. Register early & save!
http://p.sf.net/sfu/rim-blackberry-1
