I wonder how can I add cleanly a jscalendar input thing.
I make the CreateObject(‘phpgwapi.jscalendar’) and the
$cal->input(…), but I get JavaScript erros, because the css and the
js are not included at all (so, got ‘Calendar is not defined’).
In the jscalendar object constructor, i noticed the variable
$GLOBALS[‘egw_info’][‘flags’][‘java_script’] is set with the needed
includes.
So, how can I include that code? may I just “echo” that Global
variable? or there is a cleaner aproach? Perhaps
class.javascript.inc.php has something to do with all this?
TIA
Regards.
Alberto Giménez
