How to disable multiple classes?
By default it is 'disableClass' => 'isDir'.
I tried 'disableClass' => array('isNoParse', 'isDir'), but no effect.
I don’t believe multiple classes are supported, but if you can find a
contrary example I’ll be happy to be wrong.
And also the icon, 'icon' => 'parse', it is not appearing. I added it
parse.png icon in the same path as filesave.png icon.
Thanks.
A logout / login may be required to pick up the new image.
No, Admin >> Clear cache and register hooks also clears image cache and
therefore forces a rebuild.
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
