Hi Joydeep,
I use default imap server with v1.2 (and works with TLS).
sorry, but I can’t help you about courier/postfix problem (I never used it).
good luck!
Flávio
JOYDEEP j.bakshi@unlimitedmail.org esceveu:
Flávio Henrique wrote:
Thanks Flavio.
I have seen that setting but it has no effect as TLS/SSL in not enable
at server level. Could you kindly
sugest how to enable it with courier imap and postfix ?
thanks
Go to Admin > emailadmin
create/edit a profile…
the tab “POP3/IMAP” has the options to enable TLS/SSL…
Flávio Henrique
Dear list,
Could any one kindly suggest how to enable TLS/SSL with IMAP in eGw 1.2
thanks
Join SourceForge.net’s Techsay panel and you’ll get the chance to share
your
Esta mensagem foi verificada pelo E-mail Protegido Terra.
Scan engine: McAfee VirusScan / Atualizado em 05/12/2006 / Versão:
4.4.00/4911
Proteja o seu e-mail Terra: http://mail.terra.com.br/
your
your
Scan engine: McAfee VirusScan / Atualizado em 06/12/2006 / Versão:
4.4.00/4912
