1 / 9
Mar 2021
Hi all,
I want to mount external share folder on filemanager , the share is configured on qnap ,
I have try trhis command
sudo docker exec egroupware /usr/share/egroupware/filemanager/cli.php --user dino --password xxxxx mount smb://polizzi:xxxxxx@10.0.0.126/dati/ /var/lib/egroupware/default/files/dati/
but I receive this error:
cli mount (long=0, numeric=0, recursive=0) smb://polizzi:xxxxx@10.0.0.126/dati/ /var/lib/egroupware/default/files/dati/
mount: no such file or directory!
cli smb://polizzi:xxxxxx-1@10.0.0.126/dati/ (long=0, numeric=0, recursive=0) /var/lib/egroupware/default/files/dati/
share access data
share ip: 10.0.0.126
share name : dati
user: polizzi
password: xxxxxx
root_admin
user: dino
password: xxxxx
Wich the correct command for mounting network share folder?
Can you help me?
  • created
    Mar '21
  • last reply
    Mar '21
  • 8
  • 1.9k
  • 3
  • 3
    links
You mount into EGroupware virtual file system, NOT the host file system:
sudo docker exec egroupware /usr/share/egroupware/filemanager/cli.php --user dino --password xxxxx mount smb://polizzi:xxxxxx@10.0.0.126/dati  /home/dino/dati
The above will access the smb-share as user polizzi with password xxx and mounts using EGroupware user dino, who must have root rights / be listed for root in setup. Alternativ use --user root_admin --password <password-of-setup-user-admin>.
If the smb share is accessible for every EGroupware user with the same password as used in EGroupware, then it makes more sense to use smb://$user:$password@.... which will use the users own identify to access the share.
Stefan just published a new German tutorial about that topic:
Which I will also translate.
It is not quite finished yet and may still contain errors, but I have described your task there.
I have another issue , where do I find the user root_admin? It’s the same /var/lib/egroupware/egroupware-docker-install.log ?
Tks
Yes, the root_ prefix only specifies, that it’s the setup user, which you find in the password in egroupwre-docker-install.log.
Thanks for the “hint” :slight_smile:
I have now linked the FAQ in the tutorial.
For you the English version:
