Hi
How i can purge all deleted events in database? Is it possible from the UI?
Thank you for your help.
BR.,
Z
created
last reply
- 1
reply
- 144
- 2
- 2
likes
Hi
BR.,
Z
DELETE FROM egw_cal_repeats WHERE cal_id IN (SELECT cal_id FROM egw_cal WHERE cal_deleted IS NOT NULL)
DELETE FROM egw_cal_extra WHERE cal_id IN (SELECT cal_id FROM egw_cal WHERE cal_deleted IS NOT NULL)
DELETE FROM egw_cal_dates WHERE cal_id IN (SELECT cal_id FROM egw_cal WHERE cal_deleted IS NOT NULL)
DELETE FROM egw_cal_user WHERE cal_id IN (SELECT cal_id FROM egw_cal WHERE cal_deleted IS NOT NULL)
DELETE FROM egw_cal WHERE cal_deleted IS NOT NULL
