Hi Serge,
your Mail seems to be more or less empty or just displayed very strange …
If i got that right you asked for the handling of pricelists:
This is a bit different in the community version 1.8. and the Premium
line EPL 10.1 / 11.1:
- community version 1.8: pricelists are only usable in timesheet or
infolog, if the pricelist is project-related - meening you have
specified a price for the project
- EPL can handle/use general pricelists as well as project-specific
pricelists.
To add a procect-specific pricelist you best select first your project
and add than the price for the general pricelist and/or the project. The
listing will show if this is project-related or a general pricelist -
depending what you have selected in the projectmanager menu:
- general pricelist: shows only the prices of the general pricelist
- select a project ==> you will have a additional filter in the list to
select projects again two possibilities: having in the project-selectbox
a project specified ==> you see only related priclists to that project.
Selecting “project” will show up all pricelist and mentioning im the
pricelist is a general pricelist or to which project it belongs and if
the pricelist is bookable/billable or not available.
For projectmanager you may take into account to go for an
Starter-Workshop this makes it much easier to lear more about the
projectmanager - which are advantages and whats simply not possible at
the moment …
Regards
Birgit
From: “Birgit Becker Stylite GmbH [via EGroupware]” <[hidden email]
</user/SendEmail.jtp?type=node&node=2975687&i=0>>
To: “serge pecher” <[hidden email]
</user/SendEmail.jtp?type=node&node=2975687&i=1>>
Date: Fri, 20 May 2011 06:37:26 -0700 (PDT)
Hi Serge,
Hello,
We are using EGW for several years now, and happy about it.
I am currently looking if timesheet could be used in our organization.
I have some questions :
- In some projects I can see the accounting tab, in others not. I
looked to
ACL’s, but can’t find why ???
Do you have budget-rights for these projects?
Yes for so far I can see. But for sure it has something to do with
ACL’S. The project creator has the “accounting” tab, the other users not.
There have been sometimes problems that the budget-fields are not shown
- but i did not have the problem of not getting the tab n general. May
you can try to go to projectmanager->admin->configuration and just save
it again (or change allowed accounting-types". Logout/login and try it
again.
- How do you use the pricelist ? What relation is there between
pricelist/timesheet/project accounting ???
You can create pricelists related to projects and use them in the
timesheet app
When I am in a project I can click on the pricelist menu on the left,
and create a new pricelist, but nothing indicates me it is related to
the project from where I started.
After that I can create a new timesheet, but can’t see how to
establish any link between the pricelist and the timesheet ?
thanks,
Serge
Birgit
thanks for your help
SP
View this message in context:
http://egroupware.219119.n3.nabble.com/Howto-Timesheet-projectmanager-tp2956630p2956630.html
Sent from the egroupware-users mailing list archive at Nabble.com.
What Every C/C++ and Fortran developer Should Know!
Read this article and learn how Intel has extended the reach of its
next-generation tools to help Windows* and Linux* C/C++ and Fortran
developers boost performance applications - including clusters.
http://p.sf.net/sfu/intel-dev2devmay
[hidden email] </user/SendEmail.jtp?type=node&node=2965557&i=0>
Birgit Becker
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 3147833
mailto: [hidden email] </user/SendEmail.jtp?type=node&node=2965557&i=1>
www.stylite.de
Geschäftsführer:
Andre Keller und Ralf Becker
USt-ID: DE214280951
[hidden email] </user/SendEmail.jtp?type=node&node=2965557&i=2>
If you reply to this email, your message will be added to the
discussion below:
http://egroupware.219119.n3.nabble.com/Howto-Timesheet-projectmanager-tp2956630p2965557.html
To unsubscribe from Howto Timesheet - projectmanager, click here.
Serge PECHER *
Director
SDMO nv/sa
Wijnegembaan 2
B-2900 Belgium
T : +32 3 620 16 41
Mobile : +32 475 78 20 28
View this message in context: Re: Howto Timesheet - projectmanager
http://egroupware.219119.n3.nabble.com/Howto-Timesheet-projectmanager-tp2956630p2975687.html
http://egroupware.219119.n3.nabble.com/egroupware-users-f244990.html
at Nabble.com.
Birgit Becker
[open style of IT]
mailto: bb@stylite.de
www.stylite.de
Geschäftsführer:
USt-ID: DE214280951
