Hello Nathan,
I hope I am not bugging you with my questions. I need some help regarding how the keyword ‘DISTINCT’ could be used in an etemplate application. I have rows containing repetitive data and would only have to print the distinct data. If I were using SQL then my query would look like ‘select distinct(col_name) from table;’ .
Any help regarding this would be great.
Thanks,
Sai
Could someone throw some light on how to generate hyperlinks, I have worked
with Label, Submit and Text widgets. I tried to use HTML, but could not make
any progress.
I have something similar. I have a reference number, and an ID for each row.
Use a Label, with something similar for the Name:
${row}[our_reference_number]
This will be the text of the link.
Use something like this in the Options:
,perp_ap.ui_perp_payable_invoice.edit&invoice_id=${row_cont[invoice_id]}
Note the comma at the front.
The label will be turned into a link, the resulting HTML will look like this:
20100127-2072
Nathan
[hidden email]http://n3.nabble.com/user/SendEmail.jtp?type=node&node=424863&i=1
View message @ http://n3.nabble.com/Hyperlinks-in-the-columns-using-etemplate-tp424253p424863.html
To unsubscribe from Hyperlinks in the columns using etemplate, click herehttp://n3.nabble.com/subscriptions/Unsubscribe.jtp?code=c2FpLnNyaXBhcmFzYUBzcHJpbnQuY29tfDQyNDI1M3wxNTEyNTE2Nzg0.
This e-mail may contain Sprint Nextel Company proprietary information intended for the sole use of the recipient(s). Any use by others is prohibited. If you are not the intended recipient, please contact the sender and delete all copies of the message.
