I am getting the header row twice, one of them gets filled with the rows and
other does not and I get the nextmatch widget only once.
The nextmatch widget has the pagination buttons (|<, <, > >|) search,
filters, etc. It should be used only once, on the test.index page.
Your test.index.rows eTemplate should have a maximum of two rows. The
first row is optional, and contains the headers for the columns. It
will not display data, and you should not use ${row}[field] as a value
for any column in this row. The second row of this eTemplate will be
automatically repeated, once for each record, provided it has been set
properly, as in the tutorial. (Follow links on day 5 for more
information).
I know I should not be mailing you directly, but I have not been getting any response in the forum.
You posted the same message 3 or more times. Yes, it’s frustrating to
not get a response, but if no-one could help you the first time,
nothing is going to change the more times you post. More likely, you
will be ignored. If you have more information, such as sample output
of your code, or the export of your row template, maybe someone can
give you more help.
