Problem is, a submit button submits the form, unless you already have a
custom onclick with “return false” (and some other javascript / Ajax).
Anyway you need to set a name for the button, to be able to address it:
If you submit the form, you need to set the focus eg. via javascript in
onload of body tag:
egw_framework::set_onload(‘document.getElementById(“exec[enter]”).focus();’);
or in 1.6/8:
$GLOBALS[‘egw’]->js->set_onload(‘document.getElementById(“exec[enter]”).focus();’);
Same javascript can be used to in custom onclick of button …
Tell my how to make
a form with textbox and Submit button
How to order after pressing Enter the focus back on textbox
thx guys
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
