Hey everyone,
I am new to EGroupware and want some guidance. I have been trying to set up and configure it for my team but I am facing into a few roadblocks & want some advice.
Also i have installed the system & created user accounts but when it comes to setting up things such as email integration, calendar syncing and permissions, I am feeling a bit lost. I have checked out the documentation but some of the steps are a bit unclear when it comes to setting up user roles and permissions properly.
Also, while learning about EGroupware, I came across a DevOps Course Online that seems such as it could help with some of the technical aspects but I’m not sure if that’s going to be relevant for my setup.
I have check this R39489 - in /branches/1.8: egroupware/doc/rpm-build/post_install.php setup/setup-cli.php Has anyone else gone through the initial setup and had similar struggles? Any tips or resources that could make the process smoother would be appreciated!
Thank you…
