Hello again.
I have it looks like successfully upgraded from 1.6 to 1.8 except for
two errors in the setup menu.
Too of the applications are listed as follows
icalsrv-Sources deleted/missing - V icalsrv 1.4 deleted
mydms-Sources deleted/missing - V icalsrv 1.4 deleted
And if I click on problem solution I get
Problem resolution:
"icalsrv" is broken because its sources are missing!
However the tables are still in the database.
You should either install the sources or uninstall it, to get rid of
the tables.
How do I install these “sources” or are they legacy from 1.6?
Yep, that’s what they are, check delete and they are gone …
(Given you have no files in MyDMS!)
Ultimately I would like to be able to do CalDAV if that helps anything?
Go to Admin >> Manage groups and check CalDAV/CardDAV for your default
group.
