DDear developers,
I am using icalsrv (I know, it is outdated) to get an ICS file of all
appointments of a specific user in eGroupware.
This ICS file is then automatically imported into an external calendar
via cron job. The external calender only supports importing one ICS
file, therefore I’m stuck with icalsrv.
Everything works so far, except that the dates in the ICS file are only
the current and future ones.
I would like to also have the past appointments in the ICS file, but
can’t figure out how to do it.
In the file [egroupware]/icalsrv/inc/class.virtual_calendar.inc.php I
found the function
function _fn_month_start($offset = 0)
and tried to set the offset from 0 to -24.
Tried the same in the file
[egroupware]/icalsrv/inc/class.personal_vircal_ardb.inc.php
Unfortunately in both cases nothing changed in the events.ics file
creation, the past appointments don’t show.
I would really appreciate if someone could tell me what I have to do to.
I can’t figure it out…
You want something in return? I’ll send you some German Beers, a nice
postcard, a DVD, whatever it takes if it is not too expensive…
Thanks so much,
Emil
