hi,
KaiE schrieb:
Hello Ralf,
After some restarts and some more test I think that the behaviour is as
following:
Tasks are replicated to Lightning, phone calls and notices are not
replicated. This mostly sounds to me as WorksAaDesigned because the
description in Lightning is “Tasks”. Am I right?
Is there any way to replicate phone calls and notices into Tasks or
somewhere else to Thunderbird as well?
icalsrv/inc/class.{personal|system}_vircal_ardb.inc.php search for
’task’ and replace it eg. with array(‘task’,‘phone’)
Is there any way for avoiding that a user can create InfoLog entries not
belonging to category Tasks to make sure that 100% of the tasks are
replicated with Thunderbird?
Nope without modifying the code, you can only add new (custom) types,
not delete existing ones.
ralfbecker wrote:
I will soon (probably tomorrow) start working on CalDAV for lightning. I
will probably find time to look for the tasks too.
KaiE schrieb:
Hello Ralf,
Thank you very much for this thread and the solution it provides. I
really
more and more like this software as it more and more becomes the software
that I searched for during the last couple of years.
SUMMARY: The only problem that is still open on my side is that no tasks
created from EGW web interface are sent to Lightning via tasks.ics or
default.ics.
After installing and setting up the 1.5 version from infolog it works
fine
for me as well.
I’m using eGW 1.4.003-2 + infolog from the described source here in the
thread. On client side I’m using Thunderbird 2.0.0.12 (20080213) and
Lightning 0.8 (build 2008033120).
Now I can create tasks at Lightning and see them in eGw as well. This is
really a great job!
The only problem that I have left by now is that a todo-task created
under
egw doesn’t show up in Lightning.
EGW shows three todos:
Summary: from thunderbird
Details: lets try!
Summary: and now from EGW?
Details: moment!!!
Summary: from Egw 2
Details: test
When calling
http://post.blicke.de/egroupware/icalsrv.php/unterwegs/tasks.ics
directly, I
only see the task created inside Lightning:
BEGIN:VCALENDAR
VERSION:2.0
PRODID:-//eGroupWare//NONSGML eGroupWare Calendar 1.4//DE
METHOD:PUBLISH
BEGIN:VTODO
UID:a2333bee-3bbb-48ee-b4d2-bd018e9bf834
CLASS:PUBLIC
SUMMARY:from thunderbird
DESCRIPTION:lets try!
DTSTART:20080414T220000Z
CREATED:20080415T194506Z
LAST-MODIFIED:20080415T194506Z
DUE:20080417T220000Z
STATUS:NEEDS-ACTION
X-INFOLOG-STATUS:not-started
ORGANIZER;CN=XXX XXXX (unterwegs):MAILTO:unterwegs@xxx.xxx
CATEGORIES:Geschenke
END:VTODO
END:VCALENDAR
All tasks are newly created after updating to the new infolog version.
Any idea why this happens?
Thank you very much
Kai
Telefon +49 (0)631 31657-0
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
