Under eGroupware 14.1, it seems to be the case that IMAP accounts never
fully populate during the setup process. The progress bar just goes in a
loop and never actually populates the account. I’ve tried with two
different IMAP accounts encrypted and unencrypted.
You need to elaborate a bit more what you’ve been doing.
You installed an empty EGroupware from rpm/apt/archives?
In last case archives, does Setup >> Installation check shows all green,
specially all Horde PEAR packages?
Are you then trying to create a new mail account?
In which state of the wizard does it stop?
What did you enter (apart from password of cause)?
