IMPORTANT NOTE FOR ALL SYNCML USERS. PLEASE READ!
I’ll keep this message short, in the hope it will be read:
All users who sync their devices with SyncML have to be aware that an
"initial sync" will be necessary on any synced device directly after the
next update of an EGroupware instance.
GroupDAV devices should be updated automatically and there are no
further things to do for GroupDAV devices.
Which updates are affected?
Updates from any official version <= 1.6.002
- to future 1.6.003
- to current SVN versions [branch (Revision ) or trunk (Revision )]
Updates from any SVN version
- to current SVN version [branch (Revision ) or trunk (Revision )]
Reason:
In current EGroupware versions (<= 1.6002) we did not fully match the
iCal RFC on calendar entries. This caused some hard to resolve problems
for syncing the calendar entries. With the next update we change the
contents of the calendar’s UID and RECURRENCE-ID database fields to fit
the iCal RFC.
Here’s some advice on performing the next EGroupware update:
- let your SyncML users perform a last sync before EGroupware gets updated
- tell your users to not change any entries on the sync devices until
the update is finished
- after the update, let your users perform an “initial sync” on every
device; this means to let the sync remove all the contents on the device
and refresh it with the server data; this can be done by a setting on
your device
We’ll place some further reminders for you on the mailing list and
website when future 1.6.003 or the very future 1.8 versions will be
released.
Greetings
christian
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
