Hi Hansa,
ist jetzt behoben:
https://svn.stylite.de/viewvc/egroupware?revision=53011&view=revision
Danke für die Info.
Hi all,
im aktuellen svn trunk scheitert Folgendes:
root@www:/var/www/egroupware# php
/var/www/egroupware/importexport/importexport_cli.php --definition
import-calendar-1ical --file /home/xxx.ics --user xxx–password yyy
PHP Warning:
require_once(/var/www/egroupware/phpgwapi/inc/horde/lib/core.php): failed to
open stream: No such file or directory in
/var/www/egroupware/phpgwapi/inc/class.egw_ical_iterator.inc.php on line 24
#1 /var/www/egroupware/phpgwapi/inc/class.egw_ical_iterator.inc.php(24):
require_once()
#2 /var/www/egroupware/phpgwapi/inc/common_functions.inc.php(90):
include_once(’/var/www/egroup…’)
#3 [internal function]: {closure}(‘egw_ical_iterat…’)
#4 /var/www/egroupware/calendar/inc/class.calendar_ical.inc.php(2253):
spl_autoload_call(‘egw_ical_iterat…’)
#5 /var/www/egroupware/calendar/inc/class.calendar_ical.inc.php(1118):
calendar_ical->icaltoegw(Resource id #100, ‘’, NULL)
#6 /var/www/egroupware/calendar/inc/class.calendar_import_ical.inc.php(134):
calendar_ical->importVCal(Resource id #100, -1, NULL, false, 0, ‘’, NULL,
NULL, NULL, NULL)
#7 /var/www/egroupware/importexport/importexport_cli.php(149):
calendar_import_ical->import(Resource id #100,
Object(importexport_definition))
#8 {main}
Instance=default, User=hansa, Request= http://, User-agent=
PHP Fatal error: require_once(): Failed opening required
’/var/www/egroupware/phpgwapi/inc/horde/lib/core.php’
(include_path=’/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Util:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Translation:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Exception:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Compress:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Stream_Wrapper:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Support:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Stream_Filter:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Text_Flowed:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Stream:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Mail:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_ListHeaders:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Mime:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Idna:/var/www/egroupware/vendor/pear-pear.horde.org/Horde_Nls:/var/www/egroupware/vendor/pear-pear.horde.org/Hor
in /var/www/egroupware/phpgwapi/inc/class.egw_ical_iterator.inc.php on line
24
Ein schneller Versuch die fehlenden Dateien aus einer 14.2 stable zu
kopieren scheitert leider:
import-calendar-1ical --file /home/xxx.ics --user xxx --password yyy
PHP Fatal error: Cannot redeclare class Horde_iCalendar in
/var/www/egroupware/phpgwapi/inc/horde/Horde/iCalendar.php on line 23
Könnt Ihr das bitte fixen?
Dank und Gruß
Hansa
View this message in context: http://egroupware.219119.n3.nabble.com/Importexport-im-trunk-Fehler-tp4007925.html
Monitor 25 network devices or servers for free with OpManager!
OpManager is web-based network management software that monitors
network devices and physical & virtual servers, alerts via email & sms
for fault. Monitor 25 devices for free with no restriction. Download now
http://ad.doubleclick.net/ddm/clk/292181274;119417398;o
