Hello,
I work with a debian squeeze.
I made an installation error apt-get: instead of putting as root user, I put a particular user yyy.
Trying to reinstall after purging, instead of the setup screen in apt-get, I get a message like:
/ usr / bin / php-d memory_limit = 256M / usr / share / egroupware / setup / setup-cli.php - cmd-setup-database sub_command create_db = ‘default domain =’ ‘db_type = mysql’ ‘db_host = localhost’ ‘DB_PORT = 3306’ ‘egroupware db_name =’ ‘db_user = egroupware’ ‘db_pass = xxx’ ‘db_root = yyy’ ‘db_root_pw = zzz’ ‘db_grant_host = localhost’
I have not managed to purge the installation, where to intervene for a complete purge?
thank you!
