I’m currently improving the Tine 2.0 SQL accounts class which is directly
modeled after the accounts class from eGW 1.x. While thinking about the
current implementation I discovered some things I would like to improve.
1.) If an account is able to change his password or not, is stored in the
preferences table. I will move this information to the accounts table. This
way we can implement the same feature also for the ldap accounts backend, to
be compatible with the shadow objectclass.
2.) Currently the login failures get logged to the egw_accesslog table.
That’s ok. But this information is also used to detect if an account is
blocked, because of to much login failures. If you want to unblock an
blocked account, you need to delete the rows from the egw_accesslog table.
This makes it really tough for a normal admin to remove the blocking. I will
extend the egw_accounts table to have a timestamp until when an account is
blocked. This way we can easily check if an account is blocked and also
easily remove this blocking.
3.) Expire passwords. I’ll also extend the egw_accounts table to handle
expire informations for passwords. This has also something todo with topic
1.) This way we will be able to define after which time an user CAN change
his password(maybe never) and until which time an user NEEDS to change his
password(maybe now).
After I have implemented it for the Tine 2.0 codebase, it could also be
implemented in the eGW 1.x codeline. Maybe these are good topics where we
can start trying to work togehter, as both projects will benefit from these
changes.
Lars Kneschke
CTO OfficeSpot.Net
Metaways Infosystems GmbH
our ideas for eGroupWare: http://www.tine20.org
Web: http://www.metaways.de
Tel: +49 (0)40 317031-21
Fax: +49 (0)40 317031-921
Mobile: +49 (0)175 9304324
