Probably noone will be able to assist since nobody knows what emails
server you are having, how it is set up, what your login information is
and what you have entered into egroupware and what exactly that has to
do with your smartphone…
egroupware does not offer an email server, it uses whatever email server
you have already set up. You can access this email within egroupware
using felamimail and you can access this email server outside of
egroupware, ie on your smartphone with it’s built-in email client.
Not quite sure where the connection between your email on your
smartphone and egroupware is?
Regards,
Ingo
