for 1.5 you may update to the latest revision, this should be solved since
friday.
NOTE:
You CAN NOT use 1.4 with bits of TRUNK anymore. Since some pieces of TRUNK
use
phpgwapi functionality that is not compatible with 1.4
You may step back to revision 24896 with infolog. It may be sufficient to
get that
running with 1.4.
regards
Klaus
“haksi74” Hakan.Calim@rrze.uni-erlangen.de schrieb:
Im using egw 1.4002. Everything works. Now I’m using the new InfoLog from
trunk. So I can use Thunderbird as a client. After installing InfoLog in
Setup nothing works. I get only a black screen. I’m Lookong in the apache
error.log and see the following line:
[Wed Jan 30 10:17:43 2008] [error] [client x.x.x.x] PHP Fatal error: Call
to undefined method config::read() in /usr/share/egroupware/infolog/inc/cl
ass.boinfolog.inc.php on line 185
can anybody help me to solve this problem?
Best regards,
Haksi
View this message in context:
http://www.nabble.com/InfoLog-1.5001-and-egw-1.4002-problem-tp15177234s3741p15177234.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
