I just switched from latest 16.1 version to 17.1 and I noticed few problems.
When I select a project and right-click on it to enter new Infolog entry related to this project there is correct project set in “Contact” field, but after I click “Save” button the Infolog is created without any link to the project.
When I switched to 17.1, I noticed many of my Infolog entries that had link to some project - still had that link in 17.1, but they were displayed with only “,” (comma) in “Contact” field. So I had to manually, first remove the contact and link to the project, click “Apply” and then select the project and click “Save”. Furthermore, this works in 90% cases. In 10% cases I need to repeat the procedure.
Someone else has similar issues with 17.1?
Regards!
