Hi there,
Last time, we’re trying to add infolog hook in our app but it was no luck for us because the new hook is now using the new etemplate. What I did now as part of my trial and error working out on the new infolog hook is I created a new class and whole new set of functions and I used new etemplate as well. My worry is still the infolog don’t work. I come up with this error in the chrome console: “Failed to create temp file 2 : It was determined that certain files are unsafe for access within a Web application, or that too many calls are being made on file resources.”
Do you have any test application that uses infolog hook? I used addressbook as my basis but still no luck. Maybe just a test app like you did in the wiki code corner that could resolve this issue.
Thank you.
Best regards,
Ki
