I made a cvs update from the latest cvs. I upgraded the database.
I tried the infolog.
If I want to add a new infolog entry, I got an SQL error on my
postgresql 8.1.1.
Database error: Invalid SQL: SELECT
*,pm_id,pl_validsince,pl_price,pl_customertitle,pl_modifier,pl_modified,pl_billable,(select
max(t.pl_validsince) FROM egw_pm_prices t where p.pl_id=t.pl_id and
p.pm_id=t.pm_id and t.pl_validsince <= 1139053421) AS max_validsince
FROM egw_pm_pricelist ,egw_pm_prices p WHERE
egw_pm_pricelist.pl_id=p.pl_id AND (pm_id=0) HAVING
pl_validsince=max_validsince ORDER BY pl_title
pgsql Error: -1 (ERROR: column “max_validsince” does not exist)
File:
/var/www/localhost/htdocs/egroupware/etemplate/inc/class.so_sql.inc.php
Line: 534
Function: egw_db::select / so_sql::search / sopricelist::search /
bopricelist::search / bopricelist::pricelist /
projectmanager_widget::pre_process / etemplate::extensionpreprocess /
etemplate::show_cell / etemplate::show_cell / etemplate::show_grid /
etemplate::show_cell / etemplate::show / etemplate::show_cell /
etemplate::show_cell / etemplate::show_grid / etemplate::show_cell /
etemplate::show / etemplate::show_cell / etemplate::show_grid /
etemplate::show_cell / etemplate::show / etemplate::exec /
uiinfolog::edit / execmethod(infolog.uiinfolog.edit)
*Session halted.
Second.*
If I try to edit an existing infolog entry, I got this sql error message:
p.pm_id=t.pm_id and t.pl_validsince <= 1139053592) AS
max_validsince,CASE p.pm_id WHEN 1 THEN 1 WHEN 0 THEN 0 END AS
prio,(select max(CASE m.pm_id WHEN 1 THEN 1 WHEN 0 THEN 0 END) FROM
egw_pm_prices m WHERE m.pl_id=p.pl_id) AS max_prio FROM egw_pm_pricelist
,egw_pm_prices p WHERE egw_pm_pricelist.pl_id=p.pl_id AND (pm_id != 0
AND pl_billable IN (0,1)) HAVING prio=max_prio AND
pgsql Error: -1 (ERROR: column “prio” does not exist)
File:
Line: 534
Session halted.
Compared it to the mysql based domain, the mysql domain works fine. I
can add/edit infolog entries,
Attached files not possible to delet nor from postgresql, nor from mysql
domain.
Except these issues, infolog got some new nice features, thanks!
Regards,
István
