Hello,
eGroupware complains during installation that
"Your backup directory ‘/data/egroupware/default/backup’ Does not exist"
I changed the default path (/var/lib/egroupware/…) due to the fact ,that
is was not writeable. I guess it’s because the Apache document server is
located at /var/www/http/ and the directory has to be outside the web
servers document-root! )
The ‘/data/egroupware/default/backup’ directory exists, apache is owner
and group, it’s added (only /data/egroupware) to the open_basedir directive
and read therein.
The following errormessage is given by apache:
[:error] [pid 3197] [client ::1:40510] egw_cache::get_provider(Instance) no
provider found (error instanciating provider egw_cache_files:
egw_cache_files::__construct() can’t create basepath
!)!egw_cache::get_provider:511 / egw_cache::get_provider:475 /
egw_cache::unsetCache:223 / egw_cache::unsetTree:271 /
egw_csrf::validate:69, referer: http://localhost/egroupware/setup/config.php
Just a guess: your changed open_basedir does not include your temp-dir
(also in setup >> configuration)
