I am a new would-be user of eGroupware. I am using Ubuntu 7.10 with mysql and
apache installed. I downloaded and unpacked eGW and pointed my browser (Firefox)
at the appropriate location and started by testing the installation. I got
errors as sdet out in the installation test report below. My understanding is
that this indictates that mysqld is not running. I checked the process list (ls
-A) and sure enough mysqld was not on the list. I used services-admin to check
the status of running services and manually started mysqld. According to the
process list below it is now running. But still the installation check fails.
Can someone suggest why this is? Or perhaps refer me to documentation i can read
on this issue?
Thanks very much
The installation check follows first, that the process list for your reference.
Dave
__________________ installation test output _______________
Checking the eGroupWare Installation
Passed Checking required PHP version 4.3+ (recommended 5.0): 5.2.3-1ubuntu6.3
==> True
Passed Checking php.ini: safe_mode = Off: ini_get(‘safe_mode’)=’’ = Off
Passed Checking php.ini: magic_quotes_runtime = Off:
ini_get(‘magic_quotes_runtime’)=‘0’ = Off
Passed Checking php.ini: register_globals = Off: ini_get(‘register_globals’)=‘0’
= Off
Passed Checking php.ini: memory_limit >= 16M: ini_get(‘memory_limit’)=‘24M’
Passed Checking php.ini: max_execution_time >= 30:
ini_get(‘max_execution_time’)=‘90’
Passed Checking php.ini: file_uploads = On: ini_get(‘file_uploads’)=‘1’ = On
Passed Checking php.ini: include_path contain .:
ini_get(‘include_path’)=’.:/usr/share/php’
Warning Checking extension mysql is loaded or loadable: False
The mysql extension is needed, if you plan to use a MySQL database.
Passed Checking extension pgsql is loaded or loadable: True
Warning Checking extension odbc is loaded or loadable: False
The odbc extension is needed, if you plan to use a MaxDB, MsSQL or Oracle database.
Warning Checking extension oci8 is loaded or loadable: False
The oci extension is needed, if you plan to use a Oracle database.
Passed Checking extension mbstring is loaded or loadable: True
Passed Checking php.ini: mbstring.func_overload = 7:
ini_get(‘mbstring.func_overload’)=‘7’
Passed Checking extension imap is loaded or loadable: True
Passed Checking extension session is loaded or loadable: True
Passed Checking PEAR is installed: True
Passed Checking PEAR::Log is installed: True
Passed Checking for GD support…: True
Passed Checking file-permissions of . for not world writable: root/root drwxr-xr-x
This might take a while, please wait …
Passed Checking file-permissions of header.inc.php for not world readable:
www-data/www-data -rw-------
Passed Checking if php.ini setting
session.save_path=’/var/lib/egroupware/sessions’ is writable by the webserver:
www-data/www-data drwxr-xr-x
_______________ end of installation test output _____________
___________________process list ________________________
walter@walter-desktop:~$ ps -A
PID TTY TIME CMD
1 ? 00:00:01 init
2 ? 00:00:00 kthreadd
3 ? 00:00:00 migration/0
4 ? 00:00:00 ksoftirqd/0
5 ? 00:00:00 watchdog/0
6 ? 00:00:00 migration/1
7 ? 00:00:00 ksoftirqd/1
8 ? 00:00:00 watchdog/1
9 ? 00:00:00 events/0
10 ? 00:00:00 events/1
11 ? 00:00:00 khelper
31 ? 00:00:00 kblockd/0
32 ? 00:00:00 kblockd/1
33 ? 00:00:00 kacpid
34 ? 00:00:00 kacpi_notify
122 ? 00:00:00 kseriod
147 ? 00:00:00 pdflush
148 ? 00:00:00 pdflush
149 ? 00:00:00 kswapd0
200 ? 00:00:00 aio/0
201 ? 00:00:00 aio/1
2189 ? 00:00:00 ksuspend_usbd
2190 ? 00:00:00 khubd
2237 ? 00:00:00 ata/0
2238 ? 00:00:00 ata/1
2270 ? 00:00:00 ata_aux
2359 ? 00:00:00 scsi_eh_0
2360 ? 00:00:00 scsi_eh_1
2645 ? 00:00:00 kjournald
3114 ? 00:00:00 udevd
4213 ? 00:00:00 kpsmoused
4254 ? 00:00:00 irda_sir_wq
5080 tty4 00:00:00 getty
5081 tty5 00:00:00 getty
5083 tty2 00:00:00 getty
5085 tty3 00:00:00 getty
5087 tty1 00:00:00 getty
5088 tty6 00:00:00 getty
5298 ? 00:00:00 acpid
5341 ? 00:00:00 kondemand/0
5342 ? 00:00:00 kondemand/1
5435 ? 00:00:00 syslogd
5504 ? 00:00:00 dd
5510 ? 00:00:00 klogd
5539 ? 00:00:00 dbus-daemon
5567 ? 00:00:00 NetworkManager
5581 ? 00:00:00 NetworkManagerD
5594 ? 00:00:00 system-tools-ba
5595 ? 00:00:00 dbus-daemon
5626 ? 00:00:00 hald
5627 ? 00:00:00 hald-runner
5701 ? 00:00:00 hald-addon-keyb
5707 ? 00:00:00 hald-addon-keyb
5708 ? 00:00:00 hald-addon-keyb
5711 ? 00:00:00 hald-addon-acpi
5768 ? 00:00:00 hald-addon-stor
5788 ? 00:00:00 cupsd
6040 ? 00:00:00 console-kit-dae
6134 ? 00:00:00 avahi-daemon
6135 ? 00:00:00 avahi-daemon
6157 ? 00:00:00 dhcdbd
6183 ? 00:00:00 hcid
6200 ? 00:00:00 bluetoothd-serv
6204 ? 00:00:00 bluetoothd-serv
6215 ? 00:00:00 krfcommd
6335 ? 00:00:00 gdm
6338 ? 00:00:00 gdm
6349 tty7 00:01:15 Xorg
6450 ? 00:00:00 dhclient
6571 ? 00:00:00 mysqld_safe
6640 ? 00:00:00 mysqld
6641 ? 00:00:00 logger
6917 ? 00:00:00 atd
6931 ? 00:00:00 cron
7090 ? 00:00:00 apache2
7128 ? 00:00:02 collectd
7291 ? 00:00:00 gnome-keyring-d
7294 ? 00:00:00 x-session-manag
7331 ? 00:00:00 ssh-agent
7333 ? 00:00:00 gconfd-2
7337 ? 00:00:00 dbus-daemon
7339 ? 00:00:00 gnome-settings-
7345 ? 00:00:00 compiz
7347 ? 00:00:04 gnome-panel
7354 ? 00:00:00 nautilus
7365 ? 00:00:00 gnome-volume-ma
7367 ? 00:00:00 bonobo-activati
7404 ? 00:00:00 gnome-vfs-daemo
7446 ? 00:00:02 gtk-window-deco
7447 ? 00:00:51 compiz.real
7448 ? 00:00:02 gnome-screensav
7449 ? 00:00:00 vino-session
7450 ? 00:00:00 bluetooth-apple
7453 ? 00:00:00 update-notifier
7462 ? 00:00:00 trackerd
7468 ? 00:00:00 nm-applet
7470 ? 00:00:00 python
7472 ? 00:00:00 gnome-power-man
7480 ? 00:00:00 mapping-daemon
7485 ? 00:00:00 evolution-excha
7503 ? 00:00:00 trashapplet
7519 ? 00:00:00 evolution-data-
7525 ? 00:00:00 charpick_applet
7555 ? 00:00:00 fast-user-switc
7557 ? 00:00:00 deskbar-applet
7559 ? 00:00:00 mixer_applet2
7571 ? 00:00:00 firefox
7583 ? 00:00:00 run-mozilla.sh
7587 ? 00:01:51 firefox-bin
8134 ? 00:00:00 apache2
8135 ? 00:00:00 apache2
8136 ? 00:00:00 apache2
8137 ? 00:00:00 apache2
8138 ? 00:00:00 apache2
8235 ? 00:00:00 notification-da
8311 ? 00:00:00 apache2
8313 ? 00:00:00 gnome-terminal
8316 ? 00:00:00 gnome-pty-helpe
8317 pts/0 00:00:00 bash
8362 pts/0 00:00:02 services-admin
8485 ? 00:00:00 apache2
8766 pts/1 00:00:00 bash
8818 ? 00:00:00 evolution-alarm
8857 pts/1 00:00:00 ps
___________________ end of process list ____________________________
In the worlds anti-Bush zones it is fashionable to regard him as an imperialist
redneck of limited intellectual capacities. – George Ross in Le Monde Diplomatique
