Ja , kaum macht man es richtig so geht es auch.
Allerdings habe ich nun die 16.1 , aber mit PHP7.
inux-2nqx:~ # zypper addrepo http://download.opensuse.org/repositories/server:eGroupWare/openSUSE_Leap_42.3/server:eGroupWare.repo
Adding repository ‘EGroupware (openSUSE_Leap_42.3)’ …[done]
Repository ‘EGroupware (openSUSE_Leap_42.3)’ successfully added
URI :http://download.opensuse.org/repositories/server:/eGroupWare/openSUSE_Leap_42.3/
Enabled :Yes
GPG Check :Yes
Autorefresh :No
Priority :99 (default priority)
Repository priorities are without effect. All enabled repositories share the same priority.
linux-2nqx:~ # zypper refresh
Repository ‘openSUSE-Leap-42.3-0’ is up to date.
Repository ‘openSUSE-Leap-42.3-Non-Oss’ is up to date.
Repository ‘openSUSE-Leap-42.3-Update’ is up to date.
Repository ‘openSUSE-Leap-42.3-Update-Non-Oss’ is up to date.
Retrieving repository ‘EGroupware (openSUSE_Leap_42.3)’ metadata …[done]
Building repository ‘EGroupware (openSUSE_Leap_42.3)’ cache …[done]
All repositories have been refreshed.
linux-2nqx:~ # a2enmod php7
“php7” already present
linux-2nqx:~ # zypper install egroupware-epl
Loading repository data…
Reading installed packages…
Resolving package dependencies…
The following 27 NEW packages are going to be installed:
egroupware-epl egroupware-epl-bookmarks egroupware-epl-calendar egroupware-epl-core egroupware-epl-esync egroupware-epl-filemanager egroupware-epl-importexport egroupware-epl-infolog
egroupware-epl-mail egroupware-epl-news_admin egroupware-epl-notifications egroupware-epl-projectmanager egroupware-epl-registration egroupware-epl-resources egroupware-epl-timesheet
egroupware-epl-tracker egroupware-epl-vendor php7-bz2 php7-gd php7-mbstring php7-mysql php7-opcache php7-openssl php7-posix php7-xsl php7-zip zip
The following 6 packages are suggested, but will not be installed:
egroupware-epl-jdots egroupware-epl-phpbrain egroupware-epl-phpfreechat egroupware-epl-sambaadmin egroupware-epl-sitemgr egroupware-epl-wiki
27 new packages to install.
Overall download size:25.9 MiB. Already cached:0 B. After the operation, additional 87.3 MiB will be used.
Continue? [y/n/…? shows all options] (y):
Retrieving package zip-3.0-20.3.x86_64 (1/27), 235.0 KiB (790.5 KiB unpacked)
Retrieving:zip-3.0-20.3.x86_64.rpm …[done]
Retrieving package php7-bz2-7.0.7-22.1.x86_64 (2/27), 57.3 KiB ( 23.2 KiB unpacked)
Retrieving:php7-bz2-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-gd-7.0.7-22.1.x86_64 (3/27), 163.0 KiB (412.0 KiB unpacked)
Retrieving:php7-gd-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-mbstring-7.0.7-22.1.x86_64 (4/27), 508.9 KiB ( 1.4 MiB unpacked)
Retrieving:php7-mbstring-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-mysql-7.0.7-22.1.x86_64 (5/27), 89.7 KiB (158.3 KiB unpacked)
Retrieving:php7-mysql-7.0.7-22.1.x86_64.rpm …[done (1.1 KiB/s)]
Retrieving package php7-opcache-7.0.7-22.1.x86_64 (6/27), 128.4 KiB (208.4 KiB unpacked)
Retrieving:php7-opcache-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-openssl-7.0.7-22.1.x86_64 (7/27), 96.3 KiB (149.8 KiB unpacked)
Retrieving:php7-openssl-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-posix-7.0.7-22.1.x86_64 (8/27), 57.9 KiB ( 31.1 KiB unpacked)
Retrieving:php7-posix-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-xsl-7.0.7-22.1.x86_64 (9/27), 60.1 KiB ( 31.1 KiB unpacked)
Retrieving:php7-xsl-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package php7-zip-7.0.7-22.1.x86_64 (10/27), 100.1 KiB (140.1 KiB unpacked)
Retrieving:php7-zip-7.0.7-22.1.x86_64.rpm …[done]
Retrieving package egroupware-epl-vendor-16.1.20171106-2.1.noarch (11/27), 4.7 MiB ( 27.7 MiB unpacked)
Retrieving:egroupware-epl-vendor-16.1.20171106-2.1.noarch.rpm …[done (3.2 MiB/s)]
Retrieving package egroupware-epl-core-16.1.20171106-2.1.noarch (12/27), 7.9 MiB ( 32.1 MiB unpacked)
Retrieving:egroupware-epl-core-16.1.20171106-2.1.noarch.rpm …[done (4.7 MiB/s)]
Retrieving package egroupware-epl-tracker-16.1.20171106-2.1.noarch (13/27), 450.1 KiB (1017.4 KiB unpacked)
Retrieving:egroupware-epl-tracker-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-timesheet-16.1.20171106-2.1.noarch (14/27), 341.6 KiB (413.7 KiB unpacked)
Retrieving:egroupware-epl-timesheet-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-resources-16.1.20171106-2.1.noarch (15/27), 354.5 KiB (433.0 KiB unpacked)
Retrieving:egroupware-epl-resources-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-registration-16.1.20171106-2.1.noarch (16/27), 368.9 KiB (388.4 KiB unpacked)
Retrieving:egroupware-epl-registration-16.1.20171106-2.1.noarch.rpm …[done (1.1 KiB/s)]
Retrieving package egroupware-epl-projectmanager-16.1.20171106-2.1.noarch (17/27), 781.1 KiB ( 2.9 MiB unpacked)
Retrieving:egroupware-epl-projectmanager-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-notifications-16.1.20171106-2.1.noarch (18/27), 819.1 KiB ( 1.1 MiB unpacked)
Retrieving:egroupware-epl-notifications-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-news_admin-16.1.20171106-2.1.noarch (19/27), 334.5 KiB (366.3 KiB unpacked)
Retrieving:egroupware-epl-news_admin-16.1.20171106-2.1.noarch.rpm …[done (55.2 KiB/s)]
Retrieving package egroupware-epl-mail-16.1.20171106-2.1.noarch (20/27), 726.8 KiB ( 1.9 MiB unpacked)
Retrieving:egroupware-epl-mail-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-infolog-16.1.20171106-2.1.noarch (21/27), 580.9 KiB ( 1.5 MiB unpacked)
Retrieving:egroupware-epl-infolog-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-importexport-16.1.20171106-2.1.noarch (22/27), 475.3 KiB (634.2 KiB unpacked)
Retrieving:egroupware-epl-importexport-16.1.20171106-2.1.noarch.rpm …[done (2.5 MiB/s)]
Retrieving package egroupware-epl-filemanager-16.1.20171106-2.1.noarch (23/27), 462.6 KiB (731.9 KiB unpacked)
Retrieving:egroupware-epl-filemanager-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-esync-16.1.20171106-2.1.noarch (24/27), 790.6 KiB ( 3.8 MiB unpacked)
Retrieving:egroupware-epl-esync-16.1.20171106-2.1.noarch.rpm …[done]
Retrieving package egroupware-epl-calendar-16.1.20171106-2.1.noarch (25/27), 5.0 MiB ( 8.8 MiB unpacked)
Retrieving:egroupware-epl-calendar-16.1.20171106-2.1.noarch.rpm …[done (2.0 MiB/s)]
Retrieving package egroupware-epl-bookmarks-16.1.20171106-2.1.noarch (26/27), 335.3 KiB (319.7 KiB unpacked)
Retrieving:egroupware-epl-bookmarks-16.1.20171106-2.1.noarch.rpm …[done (119.5 KiB/s)]
Retrieving package egroupware-epl-16.1.20171106-2.1.noarch (27/27), 245.8 KiB ( 0 B unpacked)
Retrieving:egroupware-epl-16.1.20171106-2.1.noarch.rpm …[done]
Checking for file conflicts:…[done]
( 1/27) Installing:zip-3.0-20.3.x86_64 …[done]
( 2/27) Installing:php7-bz2-7.0.7-22.1.x86_64 …[done]
( 3/27) Installing:php7-gd-7.0.7-22.1.x86_64 …[done]
( 4/27) Installing:php7-mbstring-7.0.7-22.1.x86_64 …[done]
( 5/27) Installing:php7-mysql-7.0.7-22.1.x86_64 …[done]
( 6/27) Installing:php7-opcache-7.0.7-22.1.x86_64 …[done]
( 7/27) Installing:php7-openssl-7.0.7-22.1.x86_64 …[done]
( 8/27) Installing:php7-posix-7.0.7-22.1.x86_64 …[done]
( 9/27) Installing:php7-xsl-7.0.7-22.1.x86_64 …[done]
(10/27) Installing:php7-zip-7.0.7-22.1.x86_64 …[done]
(11/27) Installing:egroupware-epl-vendor-16.1.20171106-2.1.noarch …[done]
(12/27) Installing:egroupware-epl-core-16.1.20171106-2.1.noarch …[done]
(13/27) Installing:egroupware-epl-tracker-16.1.20171106-2.1.noarch …[done]
(14/27) Installing:egroupware-epl-timesheet-16.1.20171106-2.1.noarch …[done]
(15/27) Installing:egroupware-epl-resources-16.1.20171106-2.1.noarch …[done]
(16/27) Installing:egroupware-epl-registration-16.1.20171106-2.1.noarch …[done]
(17/27) Installing:egroupware-epl-projectmanager-16.1.20171106-2.1.noarch …[done]
(18/27) Installing:egroupware-epl-notifications-16.1.20171106-2.1.noarch …[done]
(19/27) Installing:egroupware-epl-news_admin-16.1.20171106-2.1.noarch …[done]
(20/27) Installing:egroupware-epl-mail-16.1.20171106-2.1.noarch …[done]
(21/27) Installing:egroupware-epl-infolog-16.1.20171106-2.1.noarch …[done]
(22/27) Installing:egroupware-epl-importexport-16.1.20171106-2.1.noarch …[done]
(23/27) Installing:egroupware-epl-filemanager-16.1.20171106-2.1.noarch …[done]
(24/27) Installing:egroupware-epl-esync-16.1.20171106-2.1.noarch …[done]
(25/27) Installing:egroupware-epl-calendar-16.1.20171106-2.1.noarch …[done]
(26/27) Installing:egroupware-epl-bookmarks-16.1.20171106-2.1.noarch …[done]
(27/27) Installing:egroupware-epl-16.1.20171106-2.1.noarch …[done]
Additional rpm output:
sh:line 0:hash:git:not found
Timezones updated to version 2.2016c (538 records updated).
Timezones aliases updated to version 2017-11-06 15:15:53 (87 records updated).
file_get_contents(‘http://localhost/egroupware/json.php?menuaction=admin.admin_hooks.ajax_clear_cache’) returned FALSE
You might need to clear the cache for changes to be visiable:Admin >> Clear cache!
EGroupware successful installed
