Hello world,
I am trying to install egroupware but I get a list of error’s
Checking the eGroupWare Installation
Passed Checking required PHP version 4.3+ (recommended 5+): 5.2.4 ==> True
Passed Checking php.ini: safe_mode = Off: ini_get(‘safe_mode’)=’’ = Off
Passed Checking php.ini: magic_quotes_runtime = Off: ini_get(‘magic_quotes_runtime’)=‘0’ = Off
Passed Checking php.ini: register_globals = Off: ini_get(‘register_globals’)=‘0’ = Off
Passed Checking php.ini: memory_limit >= 24M: ini_get(‘memory_limit’)=‘32M’
Passed Checking php.ini: max_execution_time >= 30: ini_get(‘max_execution_time’)=‘0’
Passed Checking php.ini: file_uploads = On: ini_get(‘file_uploads’)=‘1’ = On
Passed Checking php.ini: include_path contain .: ini_get(‘include_path’)=’.:/usr/lib/php:/usr/local/lib/php’
Warning Checking php.ini: mbstring.func_overload = 7: ini_get(‘mbstring.func_overload’)=’'
The mbstring.func_overload = 7 is needed to fully support unicode (utf-8) or other multibyte-charsets.
Passed Checking php.ini: magic_quotes_gpc = Off: ini_get(‘magic_quotes_gpc’)=‘0’ = Off
Passed Checking extension mysql is loaded or loadable: True
Warning Checking extension pgsql is loaded or loadable: False
The pgsql extension is needed, if you plan to use a pgSQL database.
Warning Checking extension odbc is loaded or loadable: False
The odbc extension is needed, if you plan to use a MaxDB, MsSQL or Oracle database.
Warning Checking extension oci8 is loaded or loadable: False
The oci extension is needed, if you plan to use a Oracle database.
Warning Checking extension mbstring is loaded or loadable: False
The mbstring extension is needed to fully support unicode (utf-8) or other multibyte-charsets.
Passed Checking extension session is loaded or loadable: True
Warning Checking extension ldap is loaded or loadable: False
The ldap extension is needed, if you use ldap as account or contact storage, authenticate against ldap or active directory. It’s not needed for a standard SQL installation.
Passed Checking extension imap is loaded or loadable: True
Passed Checking extension gd is loaded or loadable: True
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/root/.pearrc) is not within the allowed path(s): (/home/mosgroup:/usr/lib/php:/usr/local/lib/php:/tmp) in /usr/lib/php/PEAR/Config.php on line 586
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/usr/local/etc/pear.conf) is not within the allowed path(s): (/home/mosgroup:/usr/lib/php:/usr/local/lib/php:/tmp) in /usr/lib/php/PEAR/Config.php on line 595
Passed Checking PEAR::Auth_SASL is installed: 1.0.2
Passed Checking PEAR::Net_IMAP is installed: 1.0.3
Passed Checking PEAR::Net_Sieve is installed: 1.1.5
Passed Checking PEAR::HTTP_WebDAV_Server is installed: 1.0.0RC4
Passed Checking PEAR::Log is installed: 1.9.11
Passed Checking file-permissions of . for not world writable: mosgroup/nobody drwxr-x—
This might take a while, please wait …
Error Checking if php.ini setting session.save_path=’’ is writable by the webserver: mosgroup/nobody drwxr-x—
is not writable by the webserver !!!
You will NOT be able to log into eGroupWare using PHP sessions: “session could not be verified” !!!
Passed Checking function imagecreatefromjpeg exists: True
I don’t know where to start, when it comes to trying to get it to work.
Have any of you guys get any of the error’s that I got?
and if you how did you guys fix it?
the domain that i am going to install it on is mosqueragroup.com
