Thanks - for now I have installed the 1.8.004.20121024 release which did not complain about missing dependencies. I will try installing the 1.8.004.20130322 release from the sourceforge tar package instead of using the deb packages for Ubuntu and see what happens. However, that is probably at least two weekends away.
Regards,
Debasis Datta
PHP Fatal error: require_once(): Failed opening required ‘Net/IMAP.php’
(include_path=’.:/usr/share/php:/usr/share/pear’) in
I suspect your problem is that either
a) the pear Net_IMAP package is not installed - or the path is wrong
(NOTE: it is not currently maintained
see: http://pear.php.net/package/Net_IMAP/redirected); or
>>From some *old* install notes I have, check to make sure the following pear
> packages are installed (use: 'pear list' at the command line)
> Installed packages, channel pear.php.net:
> Package Version State
> Archive_Tar 1.3.7 stable
> Auth_SASL 1.0.4 stable
> Console_Getopt 1.3.0 stable
> PEAR 1.9.1 stable
> Structures_Graph 1.0.4 stable
> XML_Feed_Parser 1.0.4 stable
> XML_Util 1.2.1 stable
Just for the record, after upgrading pear today, I have the following pear
packages installed:
[10:45 phoenix:/home/david] # pear list
Archive_Tar 1.3.11 stable
Auth_SASL 1.0.6 stable
Console_Getopt 1.3.1 stable
DB 1.7.14 stable
Log 1.12.7 stable
MDB2 2.4.1 stable
MDB2_Driver_mysql 1.4.1 stable
Mail 1.2.0 stable
Net_SMTP 1.6.1 stable
Net_Socket 1.0.10 stable
PEAR 1.9.4 stable
XML_Feed_Parser 1.0.5 stable
David C. Rankin, J.D.,P.E.
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
