Hallo Ralf,
danke für die schnelle Antwort.
Das hatte ich auch gedacht, aber:
Step 7 : RUN apt install egroupware-epl
---> Running in 9de668f84c91
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
apache2 apache2-bin apache2-data apache2-utils bzip2
egroupware-epl-bookmarks egroupware-epl-calendar egroupware-epl-collabora
egroupware-epl-core egroupware-epl-esync egroupware-epl-filemanager
egroupware-epl-importexport egroupware-epl-infolog egroupware-epl-mail
egroupware-epl-news-admin egroupware-epl-notifications
egroupware-epl-projectmanager egroupware-epl-registration
egroupware-epl-resources egroupware-epl-timesheet egroupware-epl-tracker
egroupware-epl-vendor file fontconfig-config fonts-dejavu-core galera-3 gawk
libaio1 libapache2-mod-php libapache2-mod-php7.0 libapr1 libaprutil1
libaprutil1-dbd-sqlite3 libaprutil1-ldap libbsd0 libcgi-fast-perl
libcgi-pm-perl libdbd-mysql-perl libdbi-perl libedit2 libencode-locale-perl
libexpat1 libfcgi-perl libfontconfig1 libfreetype6 libgd3 libgdbm3 libgpm2
libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl
libhttp-date-perl libhttp-message-perl libicu57 libio-html-perl libjbig0
libjemalloc1 libjpeg62-turbo liblua5.2-0 liblwp-mediatypes-perl libmagic-mgc
libmagic1 libmariadbclient18 libmpfr4 libncurses5 libnghttp2-14 libperl5.24
libpng16-16 libpopt0 libprocps6 libreadline5 libsigsegv2 libssl1.0.2
libterm-readkey-perl libtidy5 libtiff5 libtimedate-perl liburi-perl libwebp6
libwrap0 libx11-6 libx11-data libxau6 libxcb1 libxdmcp6 libxml2 libxpm4
libxslt1.1 libzip4 lsof mariadb-client mariadb-client-10.1
mariadb-client-core-10.1 mariadb-common mariadb-server mariadb-server-10.1
mariadb-server-core-10.1 mime-support mysql-common perl perl-modules-5.24
php-apcu php-apcu-bc php-bcmath php-bz2 php-common php-gd php-ldap
php-mbstring php-mysql php-tidy php-zip php7.0-bcmath php7.0-bz2 php7.0-cli
php7.0-common php7.0-gd php7.0-json php7.0-ldap php7.0-mbstring php7.0-mysql
php7.0-opcache php7.0-readline php7.0-tidy php7.0-xml php7.0-zip procps
psmisc rename rsync sgml-base socat ssl-cert tcpd ucf xml-core xz-utils
Suggested packages:
www-browser apache2-doc apache2-suexec-pristine | apache2-suexec-custom
bzip2-doc egroupware-epl-jdots egroupware-epl-phpbrain
egroupware-epl-phpfreechat egroupware-epl-sambaadmin egroupware-epl-sitemgr
egroupware-epl-wiki gawk-doc php-pear libclone-perl libmldbm-perl
libnet-daemon-perl libsql-statement-perl libgd-tools gpm libdata-dump-perl
libipc-sharedcache-perl libwww-perl mailx mariadb-test netcat-openbsd tinyca
perl-doc libterm-readline-gnu-perl | libterm-readline-perl-perl make
openssh-client openssh-server sgml-base-doc openssl-blacklist debhelper
Recommended packages:
php5-pecl-smb php5-mhash | php-mhash
The following NEW packages will be installed:
apache2 apache2-bin apache2-data apache2-utils bzip2 egroupware-epl
0 upgraded, 138 newly installed, 0 to remove and 0 not upgraded.
Need to get 79.2 MB of archives.
After this operation, 417 MB of additional disk space will be used.
Ich werde wahrscheinlich das so machen, dass ich zuerst alle notwendigen Pakete installiere und das egroupware-paket ohne recommends…
Ich muss mal schauen, was dann ein apt update && apt upgrade macht…
AndreS
