Hello everybody,
I’m installig eGroupware for the first time. I’m stuck at “Step 1 - simple application management” in the eGroupware setup.
The database has been created, but when the the “All applications” are supposed to be installed I get the following error messages:
CreateTableSQL(‘egw_config’,‘config_app C(50) NOTNULL PRIMARY, config_name C(255) NOTNULL PRIMARY, config_value X’) sql=Array ( [0] => CREATE TABLE egw_config ( config_app VARCHAR(50) NOT NULL, config_name VARCHAR(255) NOT NULL, config_value TEXT, PRIMARY KEY (config_app, config_name) )CHARACTER SET utf8 )
Table ‘egroupware.egw_config’ already exists
CreateTableSQL(‘egw_applications’,‘app_id I AUTOINCREMENT NOTNULL PRIMARY, app_name C(25) NOTNULL, app_enabled I4 NOTNULL, app_order I4 NOTNULL, app_tables X NOTNULL, app_version C(20) NOTNULL DEFAULT ‘0.0’, app_icon C(32), app_icon_app C(25), app_index C(64)’) sql=Array ( [0] => CREATE TABLE egw_applications ( app_id INTEGER NOT NULL AUTO_INCREMENT, app_name VARCHAR(25) NOT NULL, app_enabled INTEGER NOT NULL, app_order INTEGER NOT NULL, app_tables TEXT, app_version VARCHAR(20) NOT NULL DEFAULT ‘0.0’, app_icon VARCHAR(32), app_icon_app VARCHAR(25), app_index VARCHAR(64), PRIMARY KEY (app_id) )CHARACTER SET utf8 )
Table ‘egroupware.egw_applications’ already exists
CreateIndexSQL(NULL,‘egw_applications’,‘app_name’,Array ( [0] => UNIQUE ) ) sql=Array ( [0] => ALTER TABLE egw_applications ADD UNIQUE INDEX egw_applications_name (app_name) )
Table ‘egroupware.egw_applications’ doesn’t exist
CreateIndexSQL(NULL,‘egw_applications’,Array ( [0] => app_enabled [1] => app_order ) ,Array ( ) ) sql=Array ( [0] => ALTER TABLE egw_applications ADD INDEX egw_applications_enabled_order (app_enabled, app_order) )
This is followed by another bunch of “egw_application’ doesn’t exist” messages.
The tables egw_applications & egw_config don’t actually exist in the database.
I hope somebody can shed some light into my problem.
Thanks in advance
Boris
