We use the Knowledge Base application to save what amounts to an employee manual. I was trying to update one of our older articles and when I tried to save it I got an Error.
Incorrect string value: ‘\xC2 …’ for column ‘text’ at row 1 (1366)
It does not happen with every article but I don’t know if others have this problem.
Is there any way to correct this article?
