Hi Ralf.
I finished removing the deprecated code for latest upgrade version 20.1 on my local server.
However after starting the upgrade on production server, I ran into the same access log errors.
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: # Instance=default, User=vish, Request=POST https://project.qa.com:8081/egroupware/json.php?menuaction=home.jdots_framework.ajax_exec.t>
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: Creating default object from empty value in /home/www.project.com/public_html/egroupware/api/src/Db.php on line 510
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #1 /home/www.project.com/public_html/egroupware/api/src/Db.php(344): EGroupware\Api\Db->_connect()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #2 /home/www.project.com/public_html/egroupware/api/src/Db.php(604): EGroupware\Api\Db->connect()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #3 [internal function]: EGroupware\Api\Db->__wakeup()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #4 /home/www.project.com/public_html/egroupware/api/src/loader.php(79): unserialize()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #5 /home/www.project.com/public_html/egroupware/header.inc.php(92): require_once('/home/www.temps...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #6 /home/www.project.com/public_html/egroupware/json.php(110): include_once('/home/www.temps...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #7 {main}
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: # Instance=default, User=vish, Request=GET https://project.qa.com:8081/egroupware/json.php?menuaction=EGroupware\Api\Framework::ajax_ge>
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #5 /home/www.project.com/public_html/egroupware/header.inc.php(92): require_once('/home/www.project...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #6 /home/www.project.com/public_html/egroupware/json.php(110): include_once('/home/www.project...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: # Instance=default, User=vish, Request=POST https://project.qa.com:8081/egroupware/json.php?menuaction=status.jdots_framework.ajax_exec>
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: Database error (EGroupware\Api\Db\Exception\InvalidSql): Invalid SQL: UPDATE egw_access_log SET WHERE
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'WHERE' at>
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #0 /home/www.project.com/public_html/egroupware/api/src/Db/Deprecated.php(64): EGroupware\Api\Db->query()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #1 /home/www.project.com/public_html/egroupware/api/src/Db.php(1980): EGroupware\Api\Db\Deprecated->query()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #2 /home/www.project.com/public_html/egroupware/api/src/Session.php(1893): EGroupware\Api\Db->update()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #3 /home/www.project.com/public_html/egroupware/api/src/Session.php(1315): EGroupware\Api\Session->update_dla()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #4 /home/www.project.com/public_html/egroupware/api/src/Egw.php(304): EGroupware\Api\Session->verify()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #5 /home/www.project.com/public_html/egroupware/api/src/Egw.php(259): EGroupware\Api\Egw->verify_session()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #6 /home/www.project.com/public_html/egroupware/api/src/loader.php(83): EGroupware\Api\Egw->wakeup2()
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #7 /home/www.project.com/public_html/egroupware/header.inc.php(92): require_once('/home/www.project...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #8 /home/www.project.com/public_html/egroupware/json.php(110): include_once('/home/www.project...')
2020-07-29 08:48:17: (mod_fastcgi.c.421) FastCGI-stderr: #9 {main}
Production Server Details:
DB Server: MariaDB Server
Version: 10.1.34-MariaDB
PHP 7.4
Maria db is used
Lighttpd server is used
Local server details:
Mysql
PHP 7.2
Apache is used.
The upgrade was successful on the local server, I compared the schema setup file which is identical. Not sure what part of code is causing the values of the update access log query empty.
Please help
