With 17.1, I am also seeing the issue with deleting a calendar entry I have with 16.1.
I am raising it here as I noticed something new.
Steps to get the error:
- Create a calendar entry (named “test”)
- “Save” entry
- Delete the entry (either by double-clicking and clicking on “delete” or by right-clicking and then selecting “delete”)
- Error occurs
Error does NOT occur when, between steps 2 and 3, I edit the entry and add a random file.
Error ALSO does not occur when, after saving with random file, I then edit the entry again to delete the random file.
My guess: When the web interface wants to delete the entry, it fails because the relevant folder under /apps/calendar/… does not exist.
This folder does exist after adding any file.
This seems to be correct, because when I manually create the corresponding folder “/apps/calendar/<calendar_entry_number>” , I can delete the entry manually as well.
Also, without this folder in /apps/calendar/ being present, I am unable to link an existing file in the VFS.
I do not, however, see any errors while creating the calendar entry and I do not know at which stage that folder should be created.
For clarity, this is with PostgreSQL
