Hi Sebastian.
R29484 svn for Trunk or 1.6.00x?
Assuming you have the default emaildomain set, and the profile is used, and
SMTPAuth is not true, then your egroupware should not attempt to
authenticate.
Possible reason for still trying to:
The profile is not used/applied.
you may increase debug-information on this by setting the $debug var to 10
in phpgwapi/inc/class.send.inc.php
Output goes to your webServers error log.
14:09:21 +0100
Hi!
I have installed postfix and cyrus on the same machine where egw is
installed (everything works fine so far).
So, I changed the settings of the default profile in emailadmin, on the
SMTP tab I choosed ‘standard smtp server’ and left SMTP Auth disabled
because I don’t want to use it atm.
I am expecting that felamimail will not send an AUTH command with this
setting, but it does. Authentification and sending the email fails,
accordingly.
All other services of egroupware depending on a working smtp setup are
failing, too.
I’m using R29484 svn. I try to append the wireshark logfile to this
message.
Does anybody have a similar setup without SMTP AUTH? Can anyone help? Is
this a bug in felamimail or emailadmin?
Thanks!
Sebastian
[ open style of IT ]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon 06352 . 70629-0
fax 06352 . 70629-30
www.stylite.de
Geschäftsführer: Andre Keller, Gudrun Müller, Ralf Becker
USt-ID: DE214280951
